Creeking/clunking noise with new lift normal?
tamadabee128
Hey guys,
Just put on a new ICON extended travel lift and ICON UCA's. Just curious if a creeking/clunking/popping sound coming from the front is normal...I can recreate the sound when I slowly make a LEFT or RIGHT turn while creeping up my driveway or speed bump (rocking side to side motion). Going head on typically does not recreate the noise...Do I just need to let it settle and break in?
Its the sway bar hitting the lower radiator support on the left side. Take off your front skid and you'll see. I ended up using a couple thick washers and longer bolts on the support arms and it gave me just enough clearance for the noise to go away.
I had to add a lot of extra spacers too and bought longer bolts just to clear the sway bar and radiator support which left me thinking did I install everything correctly? My stage 5 Icons creak here and there and they're pretty new too. I bought a grease gun and gave the UCA zerk fittings some pumps of lube which helped some most of the creaking. I also shot the top of the coilovers with lithium grease.
The bottom spherical bearing needs it a lot more than the top. They tend to wear out at about double the rate of the top bearing.
awesome, thanks guys...is this something i need to fix ASAP or is it okay to drive on it for a while?
I also KDSS...don't know if that effects anything...
i have kdss and i solved a previous rattle i had by putting on new sway bar bushings and new LR UCA's. since you already have new UCA's i'm wondering if you need new sway bar bushings (front set of 4 is roughly $60)
LOL of course it does!
This is exactly why you put what type of truck you have in your sig (or at the very least a "garage" with your trucks info)... so when you ask questions people know how to answer according to what you model/trim and options you've got ;): :)
Thanks Jeremy. Icon needs to send out a description of what type of lube and places to lube all there stuff or at least a maintenance page or something. It would be helpful to help care for their parts and accessories. I'll be sure to spray the lower spherical bearings when I get a chance.
TerryNap61
