wfo9
I originally tried this, (I used a pencil eraser not a bolt) and as it turns out the plastic threads inside the knob need to be screwed in pretty far to be strong. My 5 year old kicked the shifter stepping over the center consol (very lightly) and it ripped the treads out of the know because it was only being half by about a quarter of the intended threads.
That said, I got the eraser idea from another member who has been rocking it for a long time with no issues.
I don't see how that is possible, but maybe since the eraser could compress it was not binding the threads properly. There are still many turns on the threads with this technique ~15-20 I would guess. I could not pull it off If I tried. I don't remember the exact length I ended up with for for the spacer, but it seems like it was about 15mm or so. You just have to carefully make sure it ends up going in vertically aligned with the shifter rod. It is rock solid and only took me about 20min to install.
