Decided on 5100'S
lunarsnowstorm
Good morning T4R people. Decided to go with the 5100's all the way around. Have read most of the posts regarding this issue. What I understand ( that's if I'm correct ) Raising the shock to the highest level and adding 2 inch toytec springs will leave me with a half inch positive rake. Is anybody else out there running this type of setup, and how do you like it. I noticed most people aren't raising the shocks to the highest level. Is it they just don't want to raise their ride that high or is there other issues ? Also do I need the differential drop. Any insight out there ?
There are some guys running that setup but I can't remember who. Search through the lifted pics to find what you're looking for. The highest setting won't hurt anything, but you might end up high in front. A diff drop is not required.
Thanks for the info. It gets me a little closer. I'll do a little more searching thru the pics and see what i can find. Once again thanks for your insight. I'll post some pictures when I am done.
Superflex coils or even the 1.5" day star spacer that I am running in the rear will be perfect. Go with the superflex coil...I wish I did. Gets the back a tad higher, plus you get 2" additional travel and a slightly stiffer spring.
Thanks, that does it for me. I am going to order the coils as soon as i get done writing this. Thanks for your help. Hope to post pics soon.
