Decided on pizza cutters! But not quite..
Is this something you run?! Any modifications needed? You have a lift ? GOT ANY PICS?? What you think of the cooper discoverer at vs Yokohama geolandar At?
I have around a 3" lift, and a front bumper. Minimal trimming but no BMC.
255/75/17 -10 offset. another picture as requested.
Normally that term applies to wheels and tires like this....and not to anything offroad related.
Anyone running the exact following setup..
255/80s on stock ORP wheels
with 1.25” wheel spacers
and 5100s @ 1.75” in the front, stock rear
this is the route I wanna go
ToyTec Ultimate 3" lift (about 2.5" in the front with the bumper on 650lb springs) Discover ST Maxx LT 255/75/17 on stock Trail wheels with 1.5" spacers.
Sent from my Pixel 3a using Tapatalk
Where did you get your bumper, Custom Fab? I’m looking for one just like it! 4R looks great!
Close:
255/80s Cooper maxxs on stock rims w/1.25" spacers and Eibach pro truck lift (2.75" in front and 1" in back)
You will rub with that size tire.
Close:
That sounds nice! Any pics!? And you’re rubbing ? At full lock!? How do you like the size ? Would you go back to 255/75?
255/80r17 on stockers. 1.75 bilstein inch lift front, 1.25 bilstein/longer coils rear.
I rubbed the front fender liner full lock in reverse, but have since remedied that situation with the fender liner mod. No BMC needed.
Toyo Open Country A/T III 255/80R17 E load 33" pizza cutters on stock suspension and oem Trail wheels, no additional offsets. 44 psi front, 43 rear but I'll be doing a chalk test soon to dial them in. They fill up the wheel well nicely. The spare is a tight fit but it went in without having to air down. No rubbing in drive or reverse, but that's just turning the wheel from lock to lock while driving around a parking lot. If you hit a dip hard enough with the wheel turned you'll likely get some rubbing.
I had a very minor rub on the left mudflap while turning onto a side street when I hit a valley gutter at about 15-20 mph. The stock front suspension is pretty soft as we all know, and it dipped just enough to briefly make contact. No damage whatsoever. Mine is weighted down with 90 lb sliders which are symmetrical, but there is more loading on the left side with a 200 lb driver and a full tank of gas. Also, it has a 3/16" lean to the left even unloaded in the garage, so....it is what it is. I'm not getting a lift until later this year, but I have no concerns about running these tires.
Looks really good! I ended up removing my front mud flaps before I put my lift on. I had pretty much no rubbing with the mud flaps removed.
