Delayed shifting when cold, yes I know its normal but.....
I installed the TPS that i got from the yard yesterday, the problem is still there....facepalm.
Still have a MAF to try and a cluster circuit board to inspect.
Flush with a good synthetic ATF? Solenoids? Push it off a cliff??
Sent from my SM-N910V using Tapatalk
Not sure if this will help, but thought I'd post it. Found it in the FSM. :)
On a side note, my random P0301/P0300 pending codes I was getting have not come back once since I replaced the ECM, so that is cool I guess.
On Saturday I'll be inspecting the gauge cluster circuit board as previously suggested. I'll report back what I find.
So after work today I let it warm up before hooking my boat up (I keep it at work). I towed my 2500# boat and trailer to the lake about 15 minutes away and the tranny worked flawless again.
There may be some issue with the tranny but I don't think it is a major issue since it continues to work perfect once I get past the whole "won't shift out of 1st until warm".
Tomorrow the cluster circuit comes out for inspection.
The MAF is not going to keep you from shifting to 2nd. It's your transmission, since it's not the ECU.
Yeah I figured it had nothing to do with it but I grabbed one anyways since I was get some pending misfire codes occasionally.
Removed the cluster circuit board today. The connectors were a little dirty so I cleaned them up. I inspected the entire board with a magnifying glass and couldn't see any breaks or cracks. Just to be certain, I re-soldered every connection.
Stuck in 1st problem is still there.
I think at this point it is clearly something in the tranny itself....
I think I remember you saying you had the pink milkshake, correct? I'm thinking maybe that accelerated the demise of your transmission. I have a Subaru Outback with 340,000 miles that started slipping when cold but shifts much better when warm. I'm guessing it's some sort of internal seal issue.
Maybe just drive it as is for a while and start looking for a replacement. I don't know if I'd trust it for any long trips though. I helped [MENTION=102606]infamousRNR[/MENTION] replace his auto trans with one he bought from a Toyota dealership. $2200 was the best price he could find. The videos of the repair will be out soon. It's going to be a 3 part video since it would be too long for a single video.
That is a bummer. Think of it as a learning experience. I just killed a $25 carb on a trimmer by blowing out the check valve while cleaning it. Not happy having to buy another one.
If you have access to a FSM there are specs to ohm out the resistors to check to see if they are working correctly, whether throwing a CEL or not.
Keep us posted.
It could be related or not, it's hard to say Tim.
From what I've read, PMS tranny failures are more pronounced (slipping, shutter, noises, or outright failure).
Mine may be down that path too but as of right now, the tranny works perfect other than the "stuck in 1st until warm".
Not sure what to do next. Maybe a power flush?
Keep us posted.
I do have the FSM. Which resistors should I be checking? Can the solenoids be checked without dropping the pan (where are the connectors on the outside of the tranny)?.
They should be able to, though having never done it, I can't say for certain.
Let me see if i can find the link to where some guy ohmed his out.
Does anyone know where the connectors are on the outside of the tranny? If I can avoid having to drop the pan again, that would be great.
Well guys, I have some very promising news. I dropped the pan to inspect/test the solenoids. Lock up solenoid ohm test, pass. 12v power test to hear audible "click" passed. The middle solenoid, ohm test pass, 12v power test passed, audible click so it passed.
When i removed The final solenoid (I believe is the 1st gear shift) I immediately noticed something. I could feel and hear something rattling in there. The others did not do this. Plus the housing looked "burnt" or darkened in the center. Here is the crazy part (which makes sense), it passed the ohm test (probably why it was throwing a code but totally failed the 12v power test. No audible click, just a mild spark on the connector when I would give it power.
Looks like I need a new solenoid!
Fingers mega crossed
Here is a video of it. https://youtu.be/t0o_WlacJ-o
Hoping that's it. I remember suggesting it might be a solenoid issue but the fact that it didn't shift bad when warm lead people to think the solenoid wasn't the problem which makes sense.
And it never threw a code. But again, it ohms out fine.
I knew there was a chance it was the solenoid, I just didn't think it was highly likely because no code was being thrown. That solenoid is 100% bad, I'm pretty confident it should fix my issue.
Ok I did some more research and I may not be in the clear just yet.
the solenoid that is bad is actually the lock up solenoid not the #1 or #2 solenoids.
From my understanding, according to the FSM, the lock up solenoid shouldn't have anything to do with shifting from 1st to 2nd? I ordered a kit that comes with all three so all replace them all even though the other two shift solenoids tested fine (ohm and power test).
Does anyone know if the lock up solenoid can cause shifting issues?
CoaterZ_FL
