MrGrimm
From Demello
So on my version there are three supports and it sounds like the final design will have four supports.It would be difficult to put a fourth support on the drivers side due to the KDSS system.
The only supports without guests are the two rear supports on the drivers side. Due to the KDSS lines, gussets would not fit.
We used gussets on the ones we could use them on. I need to appolgize, there was supposed to be anther support that ran from the first leg to the 2nd leg, I don't think it will cause any problems not having it but it will be on the final design.
All the holes are stock holes and should bolt up to all models the big difference is the limited will need to trim the plastic.
That being said we haven't mounted them on a limited yet, so there may be an issue with the xres. If someone wants to come in for a test fit with a limited we could do verify.
