Diffinitive cell phone mount solution thread?
I am certain I have owned damn near every phone holder made and have mostly been dissatisfied with all of them. However, there are two I now use and like them both for different reasons.
iOttie...The first is the iOttie Easy One Touch 4 (iphoneX). As the name implies, you can operate with one hand, can suction mount to your windshield or to your dash with a plastic dish with sticky tape between the suction cup and the plate taped to the dash. This thing is pretty awesome. Easily flips from landscape to portrait, doesn’t budge on bad roads and has an extension (4”) if you want the phone closer to your face. I run this one in the F250. Here is a link for this one. https://www.amazon.com/iOttie-Dashb...g-Smartphone/dp/B076B27WP6?ref_=fsclp_pl_dp_1
X Grip...In the 4 Runner, I have the Ram universal x grip ball mounted to the top left corner of the radio trim.
. Although I really like the x grip and highly recommend it, it does require two hands to mount and dismount unless you know finger gymnastics. Also, it doesn’t rotate from portrait to landscape unless you loosen the ball extender which is a PITA while driving. But it holds the phone firmly off-road bouncing around and less likely to come off unlike the iOttie might rock crawling. Since I run the 4Runner on tougher terrain, it is the better option of the two for that reason. But I do prefer the iOttie overall. And on paved roads, iOttie is the best.
And neither of these mounts require any attachments or modifications to your phone or phone case. And if you have a wallet type case, both mounts will accommodate.
Subbed and looking forward to hearing what others are using.
I am going to have to give the Proclip stuff a try. Is it as good as the Ram stuff with X-Grip? I am just not up to drilling for a mount.
I have a Xvida wireless charging mount. I haven't had it off road or on anything too rough yet, but it hasn't fallen off hitting the pot holes of upstate NY which is just as bad. Plus it sits low enough that it doesn't block your line of sight looking out of the windshield.
I see why people like the ram mount. Personally I am not a fan. I hate the fact that I can’t insert or remove my phone with one hand.
That being said, I’m waiting to find a better solution.
Keep the RamMount, just order a larger size X-grip. I use the X-Grip for 8" tablet. The phone (Samsung S7) easily slips in and out of the bottom pair of nubs with one hand but has enough tension to stay on all but the hardest hits off-road. I had tried using a smaller X-grip but, like you, hated I couldn't get it in/out one handed.
Picture shows the top pair of retainers in use, but it was shortly after I installed it. I've since gone to using the bottom pair so that it doesn't interfere with the volume and power buttons.
More Info
158509d1432249002-ram-mount-x-grip-ii-phones-tablets-phone-jpg
Sorry if the picture is a weird size. It’s a cropped screenshot.
I went with the Expedition Essentials T4RPAM. It’s going to be more expensive and labor intensive to install but it’s a solid product. You can mount ram mounts all over the place and they sell phone specific mounts that hold the phone in place but can it can be removed with one hand. I’ve driven with my phone mounted down the Denali highway in Alaska and my phone didn’t budge (one or the worst ‘roads’ is the US). Plus if you choose to get it with the option, you have 2 additional USB ports so charging cables aren’t all over the place. I also have to add it will block your clock which is ok with androids because you can set the time to be displayed on the lock screen but my dumb new iPhone won’t let me. Plus it’s very adjustable. Since that picture, I’ve moved my phone to the other side of the power button which is out of the way of the radio screen, all the buttons, my hands don’t hit anything while turning the steering wheel or hitting the windshield washers, and it’s no higher than my hood scoop.
Edit: Reading is fundamental - Just saw you're not a fan of vent mounts. Oh well.
This is hands down the best solution I've found. Credit goes to [MENTION=44305]weeeee[/MENTION].
https://www.toyota-4runner.org/2219313-post31.html
No drilling into the dash, no adhesives to weaken in the summer heat, no magnets. Just a solid mechanical mounting solution. I've been using mine for probably year. This setup is rock solid. Doesn't block my vision of the road or the LCD screen. Blocks that one vent a little, but I don't miss it.
Based on this post, I just had all the pieces parts delivered and installed it a few minutes ago. This is an excellent, solid solution. It's not going to drop my phone and it all can be removed.
While pricey - to me at least, this really is the ultimate solution.
Hi.
I liked the Ram mount idea, but didn't like the X-grip because I often switch my phone from landscape to portrait. I used Ram mount and Arkon parts.
Ram Mount (RAM-B-238U) 2.43 x 1.31-Inch Diamond Ball Base with 1-Inch Ball (Black)
https://www.amazon.com/gp/product/B002KO5XVU/ref=ox_sc_act_title_1?smid=A2XENS8LQP1A6D&psc=1
Ram Mount Composite Double Socket Arm for 1-Inch Ball Bases
https://www.amazon.com/dp/B0074WMQLS/ref=psdc_2230642011_t1_B005KWPJ04
Arkon Mega Grip Universal Phone Holder for iPhone X 8 7 6S Plus iPhone 8 7 6S Galaxy Note Retail Black
https://www.amazon.com/gp/product/B004IMCVW6/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
ARKON Car Mount VSM Kit with Drill Base for Car Installation Arkon Dual T Pattern and Garmin
https://www.amazon.com/gp/product/B00SV2M1X8/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
ARKON 25mm Ball to 17mm Ball Adapter - Black - SP25MM17
https://www.amazon.com/gp/product/B01MZXRSST/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
I just did the Proclip vent mount paired with a RAM Mount 2 x 1.7 inch ball base and X-Grip and this is the best combo ever. I didn't even bother with using the Proclip tape as the attachment is that secure. You'll see what I mean if you go for the vent mount. They also have a 10% coupon (10now) to make the choice a little easier.
I did try the RAM Mount near the top left of the radio dash like everyone else but I found that the steering wheel would block the bottom left of my phone view just a little. Using Google maps this would be the ETA and distance to location area which bothered me a bit.
I found the perfect solution. This mount is great. I originally ordered an aluminum mount from tackform that is designed for a motorcycle. It was really well made but the grip was just too tight for daily use in the 4Runner. I called the company and they were very helpful in finding a solution. This new mount is great. It’s adjustable and it’s very easy to insert and remove my phone from the mount with one hand. I also like the clean look of the mount. I’m pumped!
I tried an X-Grip, Pro-clip, and the aluminum tackform mount before figuring this out.
So link? What mount are you talking about?
erinobr2000
