305/505 springs and 700/705 shocks with Dobinsons UCAs. 275/70/17 Wildpeaks.
Have you done fender measurements yet?
302/505 springs and 700/705 shocks with Dobinsons UCAs. 275/70/17 Wildpeaks.
Negative. Will measure at lunch and update.Have you done fender measurements yet?
Sweet! No rubbing at all. It's perfect. Completely transformed the ride for the better.Nice!I have the same setup coming but I went with the 574 shocks up front.After seeing your pic I know I made the right choices. I have same size tires as you which rub a little at full lock in reverse do you have any rub after installing the lift?
Wasn't sure where to measure from since I'm new to this
Middle of the hub (middle of the center cap) to the edge of the fender (vertically)
Heaps of guys are, I'm sure some will chime in. Ride quality depends greatly on the shocks and struts you use, since they can be valved any different number of ways.Is anyone running the 314/325 set up? Just curious how the ride quality is?
What are your hub to fender meaurements? How much difference are you seeing?Any insight on this..
Only Rear passenger side is sagging. Fronts measure fine and even
No weight in the back. Took everything out. I jacked the car up to let the suspension drop but once down goes back to the same sag.
Shocks show no sign of leaks.
Tire pressure is all same.
What else should I check to see what's going on?
Gas tank is full. Sag is there full or empty
2017 TRDP with C59-325. Springs have been on the car since 2017 Aug.
Sent from my ONEPLUS A6013 using Tapatalk
Looking to order the kit for my 2019 5th Gen. Anyone aware of any Christmas sales or discount codes?
Is it possible to order a Monotube setup without the remote reservoir?
Hmmm I dont think so. If you want monotubes without reservoirs check bilstein or icon stage 2. Why dont you want the reservoir?
Actually, Icon stage 2 was exactly what I had in mind. The reason would be to get a monotube shock over the baseline twin tube design but without the RR which i do not foresee needing. I do not intend on going fast over washboards especially for prolonged periods so I don't see fade as a major issue for me and my style of driving that would warrant a RR with its added complexity and cost.
They make a non res mono tube. It’s called an IFP. I wanted them a year ago but I can’t remember if they didn’t have them in the US or if was the cost.
