Dobinsons 5th Gen T4R Suspension options - from Exit Offroad
Maybe someone will chime in. Seems most guys who added the dobbinson suspension lifts added to a non Pro 4runner. Unless I missed someone on here that it was posted anyone replace there Pro fox suspension with this suspension. Also what do you do about the fox rear shocks because they come with the reservoir shocks for the rear.
I think there may be someone here who put the suspension on a Pro but I could be wrong. Keep in mind that Dobinsons has the MRR and MRA options as well.
Any pictures of it on the ground? I have almost the same setup but with 701s in the rear. Just waiting to get them on.
I need to get pics on level ground. This was in my driveway on an incline. It sits pretty level. Hope the front settles an 1”. I was hoping to keep 2” of rake higher in rear but only have an inch. The combo of 300/574 front gave me a little over 3”.
The garage photo is on level ground but can’t really see it how level it is. Better pics coming soon.
With the Pro Bilstein, guys have been replacing that pretty often, but not so much with the Fox. I think the Fox is a higher quality product too.
You'd just unbolt the reservoir at the frame mount and keep it attached to the shock.
Thanks for the info!! Maybe that’s why I’m seeing guys with the Pro’s with the fox suspension are doing the Cornfed spacer lifts. There is a dealership not far from me do a lot of dobbinson suspension lifts new on there 4runners and tacomas and sell them brand new so you have no warranty issues. But I have not seen them do any of the 4runner Pro’s taking off the fox suspension.
Just added the latest rear Dobinsons coil to the lineup.
C59-749V - 3" Lift, Variable Rate, long travel, suits 850-1000 LB super heavy constant rear load. You can ONLY run these if you carry at least 750LBS of rear constant weight at all times, or the vehicle will be over lifted and not ride correctly. The more accessories and parts that are being made for 4Runners these days, the heavier the coils have to keep getting!!
520/520mm free height, 18mm wire diameter, 198-300LB variable rate, usually around 270LB at loaded height
Made in teal, black and red powder coat. You can choose when ordering, it's the same price.
Dobinsons C59-749V Rear Extremely HD Long Travel Coil Springs for 4Runner, FJ Cruiser, GX470, GX460
As far as I can tell, these are now the strongest true 3" variable rate coil available on the market for the 120/150 platform, and these are now the 4th option in the rear variable rate long travel coils Dobinsons has. All of them are listed in post #1 of this thread.
Share this info to your buddies if they have one of the other variants of the 120/150 platform.
Dobinsons C59-749V Give this lift and suits these models:
3.0″ – Toyota 4Runner 5th Gen – 2010 to 2020 – w/850-1000LBS Load Maximum Flex Coils
3.0″ – Toyota 4Runner 4th Gen – 2003 to 2009 – w/750-900LBS Load Maximum Flex Coils
3.5″ – Toyota FJ Cruiser – all years – w/850-1000LBS Load Maximum Flex Coils
3.0″ – Lexus GX470 – w/750-900LBS Load Maximum Flex Coils
3.0″ – Lexus GX460 – w/850-1000LBS Load Maximum Flex Coils
**C59-749V Not for vehicles with KDSS, as 3″ lift is too much and the sway bar will contact the panhard rod at full extension, leading to problems.
[MENTION=148378]Crikeymike[/MENTION] I'm on 327's currently, and after adding a rear bumper lost a bit of height. Other than the slight ride height reduction the truck seems to handle the added weight wonderfully. Any reason not to just pop in a pair (one per side) of PS59-4023 10mm spring spacers instead of swapping to 329 springs?
That's definitely a good option if you like the way it rides
Sent from my SM-G973U using Tapatalk
The 300/574 and 325/705 is settling now. In the front I initially got 3.25” of lift but has now settled to 2.75” which is where I wanted it. This is after driving around 150 miles. Rides fantastic too. Not at all firm or stiff to me.
Hey Guys
For the month of February 2020, Dobinsons is running a free Air Compressor deal with a full suspension kit purchase. Here are the details.
Purchase a full Dobinsons suspension with twin tube struts and shocks, and receive an AC80-3808 Air Compressor free with your order. $145 value
Dobinsons 4x4 Portable 12V High Output Air Compressor Kit with Bag, Hose and Gauge (AC80-3808) | Exit Offroad
Purchase a full Dobinsons suspension with new Monotube (resi or non-resi IMS) struts and shocks, and receive an AC80-3846 Dobinsons Zenith Air Compressor. $325 value
Dobinsons 4x4 Zenith Portable 12V High Output Air Compressor Kit with Bag, Hose and Gauge (AC80-3846) | Exit Offroad
The free item will automatically be added to your order, no coupons or anything required.
Regarding the IMS (non-resi) and MRA (3-way adjustabl w/resi), ETA's are variable on those products, so your order won't ship right away, but you'll still get the deal. You will be emailed an ETA when the order is placed, or can ask up front.
302/505 springs and 700/705 shocks with Dobinsons UCAs. 275/70/17 Wildpeaks.
Just a quick 2 month 5k mile update...ride height hasn't changed so it's still sitting at 23" in the front and 24"/24.5" in the rear (center of hub to fender) and quality of the ride is the same = great.
I'm curious how you think the ride quality is compared to stock. Everyone here says it's great but mine was extremely stiff when it was first put on. Playing with tire pressure and a year of use has softened it enough so that it is tolerable, but that's the best I can describe it, tolerable. Am I just the one out of ten with a bad outcome or am I just too picky?
Edit: Forgot to mention that UCAs made a huge difference. The ride was definitely intolerable for me before that. It still seems like it should be better to me, though.
Ride quality is much stiffer than stock. That said, I actually like it more than the squishy factory suspension. Lowering my tire pressure also helped a bunch to make it less of a hard ride.
thoughts on the following? looking to be 3"/2"ish stock weight for now
302 front coils
325 Rear coils
574/705 shocks
Dobinsons UCA
Adj Swaybar links
Diff drop
SCS F5 Wheels 17x8.5 w/4.3 BSP
285/70r17 tires
302 front coils
325 Rear coils
574/705 shocks
Dobinsons UCA
Adj Swaybar links
Diff drop
285/70r17 tires
That's a very common setup. Front will be about 3.25" once settled.
matisgugle
