Just added the latest rear Dobinsons coil to the lineup.
C59-749V - 3" Lift, Variable Rate, long travel, suits
850-1000 LB super heavy constant rear load. You can ONLY run these if you carry at least 750LBS of rear constant weight at all times, or the vehicle will be over lifted and not ride correctly. The more accessories and parts that are being made for 4Runners these days, the heavier the coils have to keep getting!!
520/520mm free height, 18mm wire diameter, 198-300LB variable rate, usually around 270LB at loaded height
Made in teal, black and red powder coat. You can choose when ordering, it's the same price.
Dobinsons C59-749V Rear Extremely HD Long Travel Coil Springs for 4Runner, FJ Cruiser, GX470, GX460
As far as I can tell, these are now the strongest true 3" variable rate coil available on the market for the 120/150 platform, and these are now the 4th option in the rear variable rate long travel coils Dobinsons has. All of them are listed in post #1 of this thread.
Share this info to your buddies if they have one of the other variants of the 120/150 platform.
Dobinsons C59-749V Give this lift and suits these models:
3.0″ – Toyota 4Runner 5th Gen – 2010 to 2020 – w/850-1000LBS Load Maximum Flex Coils
3.0″ – Toyota 4Runner 4th Gen – 2003 to 2009 – w/750-900LBS Load Maximum Flex Coils
3.5″ – Toyota FJ Cruiser – all years – w/850-1000LBS Load Maximum Flex Coils
3.0″ – Lexus GX470 – w/750-900LBS Load Maximum Flex Coils
3.0″ – Lexus GX460 – w/850-1000LBS Load Maximum Flex Coils
**C59-749V Not for vehicles with KDSS, as 3″ lift is too much and the sway bar will contact the panhard rod at full extension, leading to problems.
