Does anyone have this exact suspension setup?
FORErunner911
Looking for responses from people who have this setup:
Bilstein 5100's x4
OME 884 front coils
Toytec Light Superflex rear coils
Questions im looking to get answered:
1. Do you run UCA's? Whih ones?
2. Hows the on road ride?
3. List your tire size
Ty in advance!
Looking for similar info and have reached out through PM's to a few members. I currently have a pair of Superflex that I want to use with Bilsteins and one of these:
OME 884
Toytec 521600
Toytec 112-620
Top plate spacer (1/4" or 1/2") for 3" total??????
No added weight on the front and looking for a "softer" ride as this will be for my wife's.
An older thread has the spring rate percentages greater than stock for OME's and rear Toytec (Superflex) only. I am unable to find the spring rate percentages for the Toytec 521600 and 112-620. Toytec's website states 620 lbs for each set but the 521600 is listed as HD. Is this due to longer length? Since the same 620 lb rating, will they (521600 nd 112-620) ride the same but one with less lift due to length of coil?
I found info that states OME 884 has a 590 lb rating so I assume this won't be as stiff as the Toytecs.
Not sure this helps with what your looking for but hopefully someone will chime in.
Also, maybe change your headline to be more specific i.e. "OME 884 with Bilsteins help"
I can with this.
This was my first setup and had the front adjusted to 2.5. Got a solid 3 inches from rear coils.
The on road ride was a huge improvement over stock. Noise dive pretty much disappeared and body roll was greatly diminished. The truck soaked up bumps at highway speed without all the jarring the stock suspension offered.
I've kept the rear 5100s and Superflex coils and since have upgraded to adjustable 6112s and Superflex front springs
Sent from my SAMSUNG-SM-G870A using Tapatalk
Btw, I did not need UCAS but if you're planning moderate to heavy wheeling you may want them.
OME 884
Toytec 521600
Toytec 112-620
Nope. All helpful. I dont think I can change the headline/title.
goddesszilla
