DRL burn out at 20k miles - 2014 4Runner
pj2006
Anyone have a problem with early burn out of the daytime running lights? Are these easy to replace at home vs. taking to mechanic?
Thanks.
Thanks.
Should be still under warranty, but if I was going to fix it , I would do it myself using Toyota parts. It's probably fairly easy.
Thanks.
Mine didn't burn out on my 14 and 16, but I did replace them. Easy plug-n-play. Should take you no longer than 10 minutes total for both. Especially the DRL/HB lights. If they did burn out, may as well replace them both. The DRL LED's look great but do not give the same output as the OEM DRL/HB (at least mine). You can get LED's that make the night into day, but then using them as DRL's are kinda bright especially at dusk.
I used these: Premium 9005 21 SMD 5730 LED
They don't give the same output on HB's as stock, but I have HID's and a light bar (on order) to make up for the HB's. During the day they look great as DRL's. There is a thread here: http://www.toyota-4runner.org/5th-gen-t4rs/191626-what-hid-led-company-you-using-post-pics.html post #9
