DRL LED light bulb
I won't get to it for a month or so, at least. a looot of work coming my way. But once it is done, i'll definitely post it up.
The DRL's are simply the high beams running lower current...so you would just have to change out your turn signal bulb and if you scan the threads there is lots of info on every single bulb part and what the corresponding LED part you would want is. As far the DRL I (and many) wanted to do the same thing, but it's the high beams they aren't separate. Having said that if you are adventurous you could wire up anything you wanted as the DRL's.:frisky:
completely forgot about this thread..
my soldering attempt failed - fried the bulb circuit :D twice. :D
I am wondering if those prewired resostors actually do work.. but a wee eery of using them..
ghengiskhan
