eLocker 3rd member drop in?
Since I started driving with my BAFX and keep an eye on trans temps I can get actually closer to a 340 mile range, but it means I get passed by a few Priuses and Touregs - more of an assault to my ego than wallet but I've found 70-76 MPH to be the best mileage : not-going-too-slow compromise. Lol
Sent from my Nexus 5X using Tapatalk
[MENTION=95183]octanejunkie[/MENTION]
Did you say 340 miles? :shocked:
Pardon the ignorance but what is BAFX and how do i get it? I'm happy if I can get 250 miles to the gal with about 1 gal left in the tank.
2WD... My 4Runner when it was new (V6 2WD auto w/ 15" wheels) would get 24-26mpg when driven at 65-70mph. 340 miles at 24mpg is 14.17 gallons - very doable.
Now with the 4WD system in place and larger tires (though regeared) I get 22 on road trips and aim for ~300 miles between fill ups on the highway.
-Charlie
BAFX Products 34t5 Bluetooth OBDII Scan Tool for Android Devices
I basically have to fill my tank till fuel is almost spilling out the fill neck, WHICH IS NOT RECOMMENDED AT ALL, and coast as often as I can on downhills; but yeah, 340 miles was the farthest I dared to go without spare gas on board.
I regularly drive the 323 miles from the Arco station in Mohave, CA to Arco in Gardnerville, NV on a single tank of gas - more uphills than downhills in this direction.
Others have said they get best mileage at 65-70 Mph but I can't drive that slow for 8+ hours, so my RPM goal is a compromise between MPG and no tickets :thumb:
Watching my trans temps I learned when to click out of OD, and watching my RPMs I have found that I can get better gas mileage than just leaving OD on and getting my trans up to 225 degrees on uphills - so now I just downshift and watch my Rs
Ironically, I get better highway gas mileage in an 18 year old car than Toyota originally sold it new with running 87 octane. YMMV :cowboy:
-Charlie
[MENTION=139000]phattyduck[/MENTION] - Ah..didn't see it was a 2WD. 22 mpg is still very impressive for 4WD. I'm more around 15-16 but that's a lot of local stop and go since I live close to work.
[MENTION=95183]octanejunkie[/MENTION] - Going to have to do some research on the tool and watch my OD mode. I'm in OD all day with local driving so that might be killing my mpg. There's a really popular scan gauge that everyone uses which has a basic screen(forgetting the name now), wonder if it does the same thing as your ODBII scanner? Don't want to rely on a phone.
ScanGaugeII, or the UltraGauge, but you have to have a 99 or later for Trans Temp to be accessible
Bought my entire rear elocker axle 3rd and assembly, hub to hub, for $500 back in the day. The price has certainly "inflated" since then....
Yep. If you have a 96-98 you can wire up an aftermarket gauge pretty easy. That's the route I ended up going in my 97. I played with PIDs(Parameter ID) in Torque Pro for hours to try and get it to read it. I'm tech geek who really likes math. I figured it'd be simple enough. It's not. Deci and Hex both failed. Toyota does not use the standard PID protocol for the trans temp. It was a bummer. But my piller gauge makes my truck look pretty bad ass. lol
Tx470
