Energy Suspension 8.9104R rear bump stops in place of front bump stops
Timbrens got too proud as well. I missed out on a rear used set for sale for $100. If I were to start over I would of gone with the oem GX rear bump stops ($100 a set) due to the square curvature for that positive contact point over the center of the axle. My rear Eibachs ($125 then) work but the round contact point only hits the front half of my axle. It might not even be that big of a deal after all, maybe it was designed that way. I would love to see pictures of the axle contact print on someone who upgraded to the taller stock GX bumps stops to confirm my rambling.
same..i would have went with the lexus option as well.
me too...i still won't pay more than i have to if i know there are less expensive (aka. CHEAPER) alternatives out there.
These have served me well, and are still on my vehicle.
I wont buy durobumps either, even though they probably work well.
From a design/engineering aspect and quality of materials, timbrens and ES made more sense than the durobump design.
Any loss of up travel? They feel pretty firm
Should work up front right? Looks juicy! I think it was you!
Thanks for the correction James, it's been awhile
Ok it's part of this then
I left Energy Suspension in January 2020, so I don't know the answer to that.
Before I left, we had rate tested the JL bumps and found that they're literally the perfect rate for 4Runners.
At this rate, I will bet that ES will just reuse the same bolt-in style JL bump as previously shown and then just include a couple of bolts and call it a 5th gen 4Runner set. In that case, I'd just buy the Jeep bump set and use my existing 4Runner hardware to mount them.
Jeep set includes 4, but only 2 will be usable, as the others are not meant to be bolted in.
Hi guys!
A question about the energy suspension bump stops 8.9104 for the front
I want to put them on, but unsure what there fully compressed at max force height is? Do they compress taller or shorter then stock bump stops? I do some fast off-roading, I'm looking for a little more comfort but want to make sure the bump stops engage the full stop at the same height as stock.
TIA
AndiGarage
