sunpunkT4R
I originally posted in another thread "when its not the gas cap". No replies so here we go. I am not a mechanic but I'd like to try to avoid going to a shop if possible. I'm chasing codes 0441 incorrect purge flow, 0455 large leak, & 0456 very small leak. Check engine light, blinking VSC light, & traction lights on. Codes showed up immediately after replacing the fuel pump. I had ZERO evap issues/codes before fuel pump replacement. Replaced gas cap first with Toyota part. Didn't solve. Tried an extra o-ring under the cap hoping for tight seal. Lights back on in a few days. Took it to a shop for smoke test, they told me the dreaded canister was leaking. Replaced it, cleared codes, put it thru rigorous drive cycle, lights back on in a week. I got all but one monitor complete and truck inspected. All monitors now complete. Called the mech to see if he saw any other leaks or had ideas. He suggested I replace squeeze clips with hose clamps on vac lines before & after the tank vac purge. No good either. I can't help but wonder if it may be something with the lock ring for fuel pump? I never have pressure release when removing the gas cap. I'm pretty sure we did not replace a gasket when we replaced the fuel pump. Any thoughts or advice?
