Experience with Eibach Pro Truck lift kit?
I used wheelers T12. This gave me about 2.75 to 3 inches(unloaded) in the rear on my 07 v6 . Just installed my kit (eibach shocks/struts with wheelers T1 and T12 springs). Lol, now i feel the rear is too high. I still haven't loaded my rear to see how much it comes down though.
Have about 100 miles on them in local roads (unloaded weight) for them to settle so i can get the alignment.
Do you happen to have front/rear hub-fender measurements for your setup? What perch are you on in the front? Still liking your setup? I'm thinking of doing something similar.
FYI, I contacted Eibach for more info on their springs, and they provided the following:
E30-82-073-01-20 front coils
Free length = 360mm, Rate = 720 lbs/in, Wire size = 17mm
E30-82-073-01-02 rear coils
Free Length = 373mm, Rate = 205 lbs/in, Wire size = 15.5mm
E30-82-073-02-02 rear coils
Free length = 382mm, Rate = 250 lbs/in, Wire size = 16.5mm
The first two coils should be the ones that come in the complete kit, and the last one is a new rear spring option listed on their website. I was shocked at the spring rate on those front coils, so I asked again just to confirm, and yes they are 720 lb springs. That seems crazy heavy to me (24% over stock), unless you were adding a lot of weight to the front. I would think the ride would be pretty harsh with those, no?
I will also post this info on the thread for coil springs info.
Finished the install of the entire Eibach Shocks and springs Pro Truck Sport Kit. All in all the removal of Xreas and install of the Eibach Kit took approx 10 man hours. I took my time (the front comes unassembled, so you need a spring compressor) and also had a lot of trouble with my rear shocks because the nut on the top of both struts were seized and I had to pull out the cut off wheel. I had over 200k on my xreas system, so this kit drives much better! For those who are as curious as I was, I installed the 10mm spacer and it seems to be needed and corrects any lean that might have been there otherwise. Here are the final results of lift(which you can see in my case were nil).
Fender to hub measurements:
Before Eibach-(V8 4WD, stock xreas, cornfed 2/1 leveling kit, sport wheels, BFG AT KO2 265/70-17, half tank of gas)
Front driver/passenger—- 20.5”
Rear driver—22”
Rear passenger- 22.5”(spring wasn’t seared correctly)
Eibach installed—-(nothing else changed except the Kit)
Front driver/passenger—20.5”
Rear driver/passenger—22”
So as you can see, spacer did it’s job and the kit is virtually equivalent to a 2/1 lift kit.
Any questions….fire away. I have no other experience to compare it to except xreas, which sucked so it’s hard to compare.
Do you remember which notch you had the front strut set to?
ALso, for anyone who had this installed at a shop -- what were the labor costs for you?
If using the complete kit, Eibach strongly recommends using the first notch on the strut if the 4runner doesn't have any added weight on the front.
As far as others stating the rear springs being too short, I believe that is completely dependent on the setup and intended use. For the aesthetic I was going for, this kit ended up being a little too tall for my 265/70r17 BFG KO2s. I'm going to pull the coils out and use a different setup. The shocks/struts will stay as those are great though.
What were you going for and what was the issue? Pics? Curious b/c I'm considering those tires and the Eibach kit when it's suspension time again.
I'm curious as well. I wonder if it's an offset/wheel issue? I have 265/70/17s and I'm hoping they will look great with the Eibach kit. I think they look good with the factory ride height, but my issue is rubbing.
Prior to the eibach kit, I went with tacoma trd 4x4 coils due to your recommendation in your build thread. The front height was perfect, but the tacoma shocks left something to be desired for me. After looking at the few pics I could find of the eibach kit on 4th gens, I assumed the front height would be similar with a 1" lift in the rear. I was wrong. It was taller than I expected in the front and the back, although it rides so much better now with the new shocks and struts (and that is in comparison to brand new tacoma trd bilsteins and bilstein 4600s in the rear specific for the 4runner).
My solution is going to be keeping the eibach shocks and struts, but putting the tacoma TRD 4x4 coils on the front and a new set of OEM 4runner coils on the rear with Old man emu .4" spacers. That will give me about a 1" taller rake in the rear and ride great. I don't have a pic with the lift, but I'll try to get one for comparison. Here is the wheel/tire/TRD lift setup before, where I thought the front height was perfect:
I should also add that I do not like a lot of lift to clear tires. I try to only go with as much that is needed to not rub when turning the wheel to full lock and full suspension flex.
Just a small front level of some type will cure any rubbing issue you might have. I did the fender liner mod and only because I had wheels with more negative offset before the trd pro wheels I have now.
Yeah, after getting back a labor quote to install the Eibach kit I decided to just buy a front leveling kit for now until my suspension is more worn out... right now, on stock XREAS it's super comfy.
If you really want the lift kit, just buy the tools you don't already have and do it yourself if you're mechanically inclined. That front leveling kit will be almost as much work to install alone. The rear springs and shocks are really easy if not rusted.
I am completely new to this platform (4x4) and did not want to pay a shop $500 to install my stage 2 so I did it on a Friday after work and managed to get it done under 5 hours.
workingwheelswnc
