You need a recording of speed and throttle over time to know that, you are basing this on your memory and that's not reliable. I'm also not convinced that you didn't just make a mistake calculating your mileage.55 MPH averages taken in both 2WD going up and 4WD coming back. Over 120 miles going 55MPH. 2WD 10 MPG, maybe 10.5MPG at best. 4WD 13.5 MPG.
Same stretches, same speeds there and back.
I know you meant 4hi. I just thought that 45-50 was the max?
Heavy, heavy rain, winding roads, snow and ice in higher elevations... All stated in a few posts back.I see that you are in California and Tahoe, but could you please describe why you are using 4WD on the highway when towing your trailer? Is there snow or ice on the roads.
I live in Florida and other than pulling a boat out of a very slippery ramp, don't understand why you would be towing in 4WD for long distances. We don't have hills here.
I know that 50mph or so is the max for switching into or out of 4hi to 2hi. But I don't believe it is the max recommended speed as long as you stay in 4hi.
I've accidentally left myself in 4hi for a return trip from the desert at 75 mph on the freeway and couldn't even tell. Wasn't till I was 95% home that I noticed the 4wd light on![]()
No actually uphill vs downhill will make a significantdifference
Your throttle will not be the same uphill vs downhill because the load is different
I guess I just fail to agree and see that a 3 MPG difference for the entire trip in 4WD, changed so drastically in the short time the 2WD was engaged on the ride back, especially on flat highway speeds. We can go back and forth for days as to why vs why not. Simply stated, I have experienced this on more than one occasion and for the life of me cannot understand how this phenomenon has happened. I must have a really special 4RunnerNo, 2WD vs 4WD is not the only variable
All those other things that we are talking about are variables, they are combining to cause the difference you are seeing. You can not exclude those variables, the grade being opposite is not negligible and the other things aren't either especially when you combine them all.
(although my money is still on that difference not being real)
I think its more likely that you just think you've noticed it
Plenty of people swear that putting their tailgate down increases their mpg, plenty of people swear that fuel sharks cut their mileage in half, etc...
What is the starting and ending elevation?
Sub-space gravitational waves in the time-space continuum, DARPA extreme long frequency electromagnetic wave testing or genetically modified anthophila interference
*firmly snaps up the chin strap on his tinfoil hat*
