Carova Colton
Jivewalker, thanks for the service manual. TrueType appreciate it !!
Thanks Waypoint! You da man!
Any idea on the blank shift position window on my dash?
Thank you
Thank you
Can't tell you how many times a fuse looked good to the eye and was still bad.
I pulled the plugs and went to turn over the truck to see if it would start and when I hit the push button the dash and center console electronics went dark then reenergized.
[MENTION=147877]Carova Colton[/MENTION], I didn't know you responded, so sorry for the delay. Use the "@" symbol in front of a users name, and we get a notification when we are mentioned, otherwise we have no clue.Old Red, is there a OBD2 usb cord you recommend? I went straight to Toyota and getting the software from them would be a no go. The version I would need is $65 and you have to send security documentation. Next I went to Amazon as my go to. They had some cords there and included software that would have to be run in a virtual box most likely because it’s a Chinese bootleg. Is there any one that you would recommend? That you have and works? Reviews were not very good for most of them due to the software issues. I will pull out the fluke today and read out the fuses.
Thanks Old Red, I used a fluke and read out all the fuses that you identified and they all have good continuity. The new ECM arrived and I installed it and we are getting closer to good. I am now seeing the transmission position in the window on the dash and my scan tool is talking to the truck. The only codes are mass air flow sensor because I disconnected it, air flow temp sensor because the same and cam shaft position sensor because I inadvertently ripped the wires out of it and still need to fix it. No codes that I didn’t impose. I pulled the plugs and went to turn over the truck to see if it would start and when I hit the push button the dash and center console electronics went dark then reenergized. I pulled the CAN bus like you said and there doesn’t seem to be any corrosion. I sprayed it all out with WD40 again for good measure with not change. I did notice that on the Canbus connector (mine has 2- a white plug high and a grey plug beneath it, the red wire on the grey plug had a small nick in it. I taped it up with no change. Still waiting on the cable that I ordered from Amazon. Should be here tomorrow with the Techstream software. So awesome we have more freezing rain moving in tonight! Thanks team.
