Fog light bulb upgrade
That's a lot of money for 5% better output.
I've got h9 bulbs in mine for $8 each. They end up being more like offroad lights cause of the power.
Our stock bulb is H16 — not h11, meaning that we are going to get close to double the output :)
Correct OP, I think our stock Fogs output is about ~750lm, IIRC!
Might look at TRS Morimoto LED Replacement Fog assemblies for that price!
http://www.toyota-4runner.org/5th-gen-t4rs/172771-direct-replacement-led-fog-light-assemblies-2014-other-5th-gens.html
If you decide to go that way, hit me up for a coupon code.....
Check out PIAA.com
They have high performance fog light in 2800k or 6000k. I have the 2800k, and they are bright!
How do they compare to the ones I linked?
Can't compare as I never owned any of the H11 / H8 / H16 Philips X-treme Ultinon LED Bulbs.
Looks like 1200lm per bulb = 2400lm total
3yr warranty
How will they perform in a halogen reflector?
You are only getting LED output from 2 sides of the bulb fixture, 180° at most, so you are loosing 50% of your reflector.
That being said, Philips makes quality stuff. Give them a shot, see how they do.
As far as the Morimotos, I have them and they perform very well, bright and white in color spectrum.
What's Included
Housings: Type T Morimoto XB LED (Pair)
Wiring: All necessary seals/connectors
Warranty: Ten Years
Technical
Light Source: 3x Philips Luxeon-T (3W)
Luminosity: 1200 per lamp Kelvin
Rating: 5000K Input Range:12-24VInput
Socket: H11 MaleWeather
Rated: IP67 Water-tight
Lens Material: High Impact Polycarb (UV resistant)
Shell: Cast Aluminum
People use their fog lights?
up here every guy with anything bigger than a half ton puts HID bulbs in his fogs without projectors and then runs them all the time. I'm starting to think the domestic truck dealers offer them as part of the "douchebag kit", comes with a 6" chrome tip and a Revtech lift.
Those bulbs the OP linked are amazing... I originally bought them for my Tundra, and as soon as i saw the output I ordered another set for the 4 Runner.
IMO they are worth their obscene price tag.
[MENTION=81003]Jono.ful[/MENTION],
They do the same thing in the south as well, it's not just a northern thing!
More often than not, it makes my reflex want to engage the LED Bar.....
Just sayin'
Do you have any pictures you can provide? I'm on the fence about them. Just found this and it's pretty thorough. I'll probably get them to match my HIDs. The halogen fogs look terrible alongside HID/LED headlights.
I totally trust xenon depot. Anything I have bought from them in the past is amazing. Great service as well.
i'm impressed by the quality and detail of that post you linked to but also dismayed anyone gives that much of a shit about what color their lights are and puts that much time into comparisons. i mean where does he drive his camry that its that dark and necessary to go so OCD?
Seriously, what a nerd. He's probably an.................... engineer.
[MENTION=66316]1engineer[/MENTION] [MENTION=96008]Engineer[/MENTION] [MENTION=102597]IBallEngineer[/MENTION]
I kid. I really appreciate how much time that guy put into that post. It's making my decision easier.
The review posted is what sold me on mine originally. GreatAvalon is also a huge contributor at TundraTalk.
I never took any output shots before I had my retrofit done. My projectors wash out the fog light quite a bit. If I had ordered the Philip's bulbs before my retro I probably wouldn't have done it. It's a bigger difference than you can tell in these pictures. I only have pictures of my Tundra lighting, and my wife never washes the 4Runner so I never take pictures of it.
From Front:
20150320_063849_zps1rrajlrb.jpg~original
Fog Off:
20150320_063920_zpsl5cdjxgv.jpg~original
Fog On:
20150320_063911_zps2lj3zvn3.jpg~original
Laser Beams(pitch black outside):
20150320_064203_zpsz5ui8iru.jpg~original
Very impressed by the fog light bulbs I bought. I linked them above. Which HID's (4300,5000, 600k) would match up the best with these fogs? Once I get this done I don't want them to be mismatched on the color by too much. With the headlamps having a projector and the five thag don't I'm not sure if this is possible?
TerryNap61
