FS: 1999 Toyota 4runner limited 4x4 rear locker. Chino, CA 227k $9.5k
battery1882
Sold.
Everything below done within 13k miles
I have oil report from blackstone outlining metal wear and overall condition of the engine.
Maintenance
All toyota OEM parts used except noted
Throttle position sensor
AC control panel LCD repair with lifetime warranty (common failure)
Timing belt
New Water pump
New Thermostat
New Radiator
New radiator hoses
New Radiator cap
New accessory belts
New tensioner
New idler pulley
New Cam Shaft seal
New Crank Shaft seal
New spark plugs
New plug wires New O2 sensors front and rear (front is AF sensor for California)
New starter contact (common failure)
New Lower ball joint both sides (common failure)
New inner / outer tie rods
New rear wheel bearing
New Front CVs - non OEM but lifetime warranty
Modification
B&M Transmission cooler (common failure)
Kenwood double din display with DVD, BT (Spotify, Pandora)
Spectre cold air intake
FN 5star 16x8 -25 offset
Toyo 265/70 16 plenty of life left (~70%)
Stainless steel braided brake line front and rear
Tundra front brake upgrade with new caliper/pads/rotors
New rear brake drums / shoes
ARB front bumper
Warn Winch M8000
Hella Fog lights
Smittybilt awning
Smittybilt RTT (roof top tent)
Fabtech 2.5 coilover shocks - rebuilt less than 1000 miles/3 months
OME 891 springs rear
Monroe air shocks rear - adjustable height
erinobr2000
