Jeremy556
Just wanted to post my experience to hopefully help someone else in the future.
For the past couple of years, I couldn't fill the fuel tank, as the pump would shut off after about 1/10th of a gallon, and if the tank was nearly empty, would actually eject the fuel back out of the filler. I had suspected the breather/evap canister and had simply disconnected the hose from the fuel tank to the canister, which of course cured the problem, but I had to reset the CEL every few days for the air leak.
The service manual has a troubleshooting guide for the evap system which includes checking the lines for blockage by applying a low PSI volume of air. I was lazy and was using 80psi shop air, which prevented proper diagnosis for a long time - you need to stick your mouth on the lines and blow.
There is a vent line from the charcoal canister to the filler neck, and there is a plastic filter housing that fits around the filler. Mine was filled with dirt and not allowing air to escape the canister. Part number 77745-0E010 $33.
Have to pull the fuel filler neck out partially, which means removing the access panel behind the driver rear wheel, loosening the fuel pipe hold downs, and removing the rubber surround at the fuel filler.
