GGFerrier's 2000 Limited Build Thread
Status
Not open for further replies.
GGFerrier
Proud (2nd) owner. It was my Father in Law's daily driver. I got it in late November 2015, with 160 on the clock.
First mod was the running boardectomy!
Then:
Now:
Year: 2000
Make: Toyota
Model: 4Runner Limited
Color: Desert Dune w/Mil Silver Exterior/Oak Leather Interior
Engine: 5VZ-FE Engine 3.4L V6 w/ Factory rear locker
CURRENT MILEAGE: 186k
Tires/Wheels:
- 275/70 17 BFG KO2
- OEM Sequoia wheels 17"
- 285/70 16 Toyo Open Country MT
- OEM Limited 5-star 16"
- 1.5" Synergy wheel spacers
Suspension:
- Toytec Eibach 112620's
- Land Cruiser 9 Wraps Rear Coils
- Bilstein 5100's f&r
- Toytec Differential Drop Kit
- Sway Bar Double Disco's by MStudt
- all new bushings and bump stops
- Panhard lift and drop bracket
Engine & Performance:
- Airaid
- Deckplate mod w/ K&N filter
- NGK Plugs and wires
- ScanGauge II
- Trans cooler (rad. bypassed)
7" electric pusher fan
Lighting:
- 40" Morimoto X-Torch light bar
- 20" combo light bar
- 4" spot beam ditch lights (on CBI ditch light brackets)
- 4" flood beam rear lights x2
- full interior LED upgrade
- diy footwell LED
- JDM fender markers
- OEM 2001-2002 tail lights
- amber corner and clear bumper lights
- DIY engine bay LED
Electrical:
- 1500w inverter w/ remote Scion outlets
- Bluesea fuse box
- OEM switches
- 2x 12v outlets added to backside of the center console
- ARB Compressor in rear cubby
Audio/Comm:
- Pioneer AppRadio 4
- Pioneer speakers
- Uniden 520xl w/ 3' Firestik II
- CB am/fm mulitplexor (OEM antenna removed)
Armor:
- OEM skid pan for now
- All-Pro slider w/kickout
- lotus rear control arm skids
Exterior:
- OEM Sport hood
- full length roof rack by Joe
- Satoshi grille mod w/ OEM badge from a '77 LC
- OEM Sunroof deflector (removed)
- Tacoma whip mod (remover)
- Blacked out badges
- Mercedes Hella horns
- Bedlined roof
Interior:
- WeatherTech front & rear mats
- new Limited steering wheel
Future projects
- bumpers (front & rear)
- full belly skids
- UCA's (uniball for sure)
- Tundra brake upgrade
[MENTION=102606]infamousRNR[/MENTION] recently convinced me to do a build thread and up until recently I was not taking detailed pictures of the work I was doing. I had to search all my posts to find the photos I did take. So here goes, in order...
1200w inverter install and Scion 110 outlet plug. Center console mod credit goes to [MENTION=74071]Brilliant[/MENTION]. All the switches are wired to the cigarette lighter ring for illumination.
JDM Fender marker install. Special thanks to [MENTION=46895]sogoood[/MENTION] for the JDM measurements.
Remember, measure twice or three times and cut once.
Hard to believe this is a 16+ year old engine. Waiting on some blue techflex to put the finishing touches on my new vacuum hoses.
It took some searching, but I was able to find a '99 Camry Limited wheel and airbag... $75 total at PnP. I had to use the Camry airbag because the internal mounting of the airbag and plug were different.
All you need is a torx bit, 19mm socket and breaker bar.
Couldn't be happier with the result.
I am absolutely loving this build. Hope you don't mind if I steal some of these ideas for my own 2000 Limited. The LED lighting upgrade in particular looks amazing.
Status
044runner4
