Going Bigger - 5th Gen Tire Fitment Guide
I dont have mudflaps but right there on the inner fender next to where the mudflaps would be. I will take more pics if needed. Thanks
Looking for insight on a specific set up. I have done the 5100 1.75/1 lift. I have TRD pro rims in the boxes (17x7) and have been contemplating the bump to 275/70 or 285/70. At this point if I go bigger on tires I think I'd look more to the 285s as they seem cheaper than their 275 equivalents (not to mention C load range availability).
Based on the search bar most have gone with bigger lifts or wider rims (which I get for airing down).
Can anyone with this or similar set up validate that a fenderliner push and mud flaps off should minimize the rubbing? Current caster is set to 2° if that helps.
Thank you!
Ok guys got a 2 front and 1" rear leveling kit on really wanting to go 255/80/17 on some fuel trophy wheels. Or should I go with 275/70/17?
The Limited wheels are kinda odd in that they measure close to 7.5" wide (inside bead seat to bead seat) but are stamped as a 7.0 width wheel. Not sure what's up with that. Also they do sit a bit further out than the Trail wheels.
Yeah, there is this but that conversation's done and dusted it seems
I have a 2015 TR4, Limited and looking to replace tires. I prefer all season tires and don't do a whole lot of off road. I am in Colorado area, so we see some deep snow on occasion.
Any Recommendations?
Running 295/70/17 Toyo MTs on 17x8 Countersteer Type Xs with a 1.25 spacer.
Hi all,
I have a 2016 Limited and would love to switch to 17” TRD Pro wheels. As of right now, I currently have stock suspension with Gobi stealth rack. The only concern I have is the clearance between the roof rack and the garage door. The gap is about 2.5 inches. If I swap with TRD Pro along with 275/70/17 tires, will this affect the overall height? I checked the tire size calculator and it looks like I will be fine. Can anyone confirm?
Didn't get any responses and had to do something, so here's the result:
- Ended up getting Goodyear Duratrac's, 255/75/17 and put them on a TRD pro rim (7")
- Rim widened stance a good 2" total
- Tire clears suspension parts no problem
- Major rubbing at front and back of fender. Had to remove mud flaps and cut out some of my fender liner
- Still get rubbing on frame behind strut tower on R side when wheel turned all the way to the right
- Spare fits in holder. Barely
- Will probably have to get a leveling kit, feels like the clearances are too tight
Pics:
This thread is for 2010+ 4Runners. While it can be used for the 4th gen 4Runners, there are some differences too.
Pics:
Nice, looks good. Something just to keep in your mind and something you could probably report back on:
Duratrac 255/75s are P-rated. Great for the street, you'll still get good traction off road, but for a tire that's already perceived to have a weak-ish sidewall, a P-rated tire won't help. The BFGs would have been C-rated, so they would have been heavier, not rode as well, etc, but supposedly would have a tougher sidewall.
Will 16" TRD FJ Wheels fit over the 2017 4Runner calipers? I like the taller sidewall for off road reasons. Seems there are more tire options in a 16" wheel as well...
As engineer said, they will not. Lift it more, you'll have room for bigger tires with more sidewall!
