Good gas mileage
ARIZONA4R
Just did a trip from tucson az. elevation 2,300 ft. too Pinetop az. elevation6,700 ft all mountain driving 417 miles round trip 16.577 gal. 25.15 mpg.I have almost 12,000 miles on a 2010 2wd. very pleased !!!!
25MPG? What? How is that possible, uphill none the less? What was your average speed? How is your 4R setup?
Ever since I switeched to regular gas (not reformulatted and no ehtanol) my mileage has been great! I am very pleased with the gas mileage in this truck.
EXCELLENT LINK !!! Thank you.
I have been get excellent city milage . between 18 and 19 (figured the old fashioned way) . I really don'y have and mods except AT tires . Now that we switched to summer blend fuel it went up 2-3 mpg which is normal here .
I did speed limits posted ranging from 35-65 mph. mpg up 24.5 mpg down 26.0 . On chevron reg. Used speed control when possible and light foot on pedal. my wife and i always try to see who can get the best mileage
The way i fiqure mileage was total gallons and mileage on odometer .I also compare it to reading in dash usually a diff of about .6 mpg in total
I had the same thing happened to me this weekend. I filled up in Galveston, Texas on the way to San Luis Pass (50mph speed limit) and averaged 27MPG (brother in law was amazed as his LR3 gets 15MPG downhill in a hurricane). From San Luis Pass back to Houston, ended up with 24.3MPG (70MPH on the freeway). I have a 2011 SR5 2WD with 9500 miles on it.
impressive. i got 23.1 mpg in my 2011 4wd SR5 after a fresh oil change running 70 mph up and down steady hills on the interstate.
that was with regular 10% ethanol bs gas.
i've heard none-ethanol fuel givse 7% better mileage? if you take that into account it would have been 24.7mpg in a 4wd. coulda, woulda, shoulda. i may have to fill up with no ethanol one day and test it out.
My wifes 11 is averaging 17 MPG! Really not happy at all! closest non ethanol station is 70 miles away.. boo.
With lower ambient pressure you can get better MPG at higher elevations, but the power of the engine is also somewhat reduced. Your engine can also use lower octane. That's why fuel sold in higher altitudes has a reduced octane rating.
Koz
We are probably getting better milage up North here in Canada because most of our gas doesn't have ethanol. Except for Husky/Mowhawk stations which do have ethanol.
Round trip to Radium Hot springs and Back to Calgary with 15 km of rough 4X4 roads: 24.7 MPG calcultated by filling up tank - also matches what my gauge said. The worst mileage I've got on the highway is about 20 MPG with winds. My ride isn't even broken in yet - I've got just over 4000 KM (about 2.200 miles)
My first highway trip we got 22 MPG with a thule on the roof.
Basically I realize if you drive a reasonable speed, this rig can actually get respectable gas milage! I am really impressed!
I recently lifted the truck by installing the full 2.5 RADFLO kit from overland warehouse. I was amazed on my first trip to the mountains and back, to get 23.4 MPG! I will add to this report after my weekend trip...
Keep in mind the trip I'm measuring the milage on is mainly slower 55-60 MPH roads, although there are several full on mountain passes on route.
Tires: stock sized Toyo Open Country AT
Even with my wheel alignment issue, my 4R alternates between 22 mpg and 18.something mpg. It seems pretty random, even when buying gas from the same place.
I know on mine the gas mileage does start to plummet when highway speeds exceed 75 mph or so.
I've asked this in another post, but is there a way to reset the computer to relearn and help improve gas mileage?
It won't improve mileage, it just changes the timeframe over which data is measured.
If you have the nav unit, under options there is the mileage graph that allows you to do a full reset.
You can do a partial reset, probably good enough for what you want, either by holding down the "set" button on the center display, or pressing the button that zeros the trip odometer when your odometer is showing average mpg.
How are so many people getting above 17 mpg? Are you all 2wd owners?
The max mileage I get according to the dash is 16.8mpg and the last tank got 350 miles per tank.
