Greasing the driveline
bucknasty07
So I want to grease up my zerk points, but I can't seem to find an answer to my question. When I grease my zerk points, don't I pump grease in until all the old grease has been pushed out and new grease starts to come out? Others have said to never do that because you may cause damage. But that doesn't make sense to me. Thanks in advance!
Yes and no.
Do the u-joints till you see grease ooze out.
The slip joints are the ones you don't want to over do. Consensus is you can cause damage. Just a couple pumps, if you get that brake 'let off' clunk, give it another couple pumps.
U-joints (nipple hard to see, one at each end of both front and rear) pump till you see new grease. Slip yoke (easy to find, one on each drive shaft) I've heard many different things. Asked a buddy who was a Toyota mechanic and he said you can just keep going, shouldn't hurt.
Sent from my SM-N920T using Tapatalk
+1 on what's already been said...with a caveat. The U-joints, pump away. Push out the old and in with the new.
The slip yoke I went ahead and dropped the shaft last time (I was working on the t-case anyway). I marked it, pulled it apart, smeared grease on the splines, and put everything back together. It didn't take long. There's a pretty big cavity where the two fit together. I'm not sure how much grease that will hold but it's a lot.
However, if you've ever done the "pump till it's full" it acts like a big piston. You can actually watch as the two parts of the driveshaft are pushed apart (slightly). Much like in other hydraulic pistons, the liquid doesn't compress and has to go somewhere. So lets say you fill that cavity slap full of grease and now the driveshaft can't compress. Then right out of the gate you decide to go hit some huge bumps. All that rear axle movement is going to be transferred right up the shaft and into your T-case. Not good.
After you drive a day or two and let the grease and drivetrain heat cycle it's going to push/sling out a good part of that lubricant. This leaves free space again for the splines to move in/out. In a nutshell, that's why the "clunk" comes back. If not, you'd be able to grease it once and be done. Long story short...don't pump the driveshafts full of grease then immediately go run the Baja 1000 or try to catch air on the parking lot speed bumps :cowboy:
On the u-joints, pump until a little bit of grease comes out of each one. If you pump until nothing but new grease comes out, you're going to have a mess on your hands and it's really going to splatter all over the underside of the vehicle and on the road. I would grease the slip joint as mentioned previously.
Crookedcat
