How are you pulling down this roof console?
Is it held in place by velcro, screws and clips? I tried to pull mine and it wouldn't even move.
X2 for me
how did you terminate the twisted pair to a 3.5mm jack for your Kenwood?
A/V1 & Honda_Nos: What wires (color) on the O/H of the Lexus console did you use to get the mic to work? Thanks!
sorry for bringing up an old thread but does anyone have a part # for the 2 metal clips? I need them and any dealer I ask says you have to buy the whole console. that seems a little ridiculous to me.
does anyone think that these will work?
[MENTION=9622]A/V1[/MENTION]I don't think you will have the results you are wanting by grounding the LED black wire to the green wire. It's true that the green wire is the ground for the map lights, however, the ground is supplied through the body ECU, and therefore may not be constant. Well, most likely ISN'T constant. The body ECU is what controls the lamp fade (power for the lamps goes through it as well, but that is only for the ECU to remove power to shut them off after they've been left on after so many minutes).
I would run three regular unshielded wires, and one shielded twisted pair for the mic if you are going to use it. It's pretty simple to run wires up the A pillar - just be sure to run them (and secure them) behind the side curtain airbags. Ground the black wire to a chassis ground. I ran the yellow wire to the lighting wire of one of the dash panel switches (I did this when I relocated my DAC switch, which I was coincidentally doing at the same time). The brightness on my LEDs varies with the dash light switch this way. Pretty nice to be able to adjust them.
The ground with door open (blue wire) I wired to the body ECU, middle plug - pin 6. This allows the lamps to fade out just as the other dome lamps do, and is a common ground output for all of the doors (if you notice, each door has a separate ground to the ECU so it "knows" which one is open). If you were to connect to one of these outputs, the map lights would only come on when that one door was opened.
And if you truly wanted to, you could actually take the sunglass holder off the 4runner one, and swap it with the Lexus one so it doesn't stick down. But it hasn't bothered me in the several years since I installed mine.
And yes, that is grey! LOL
@A/V1
Hey Brad, couple of questions if you don't mind.
1) The Blue wire (which you connected to the body ECU), keeps the map lights on when a door is opened and fade to off when closed?? With pin 6, do your lights come on when any door is opened or a particular door?
2) When you say 3 unshielded and 1 shielded wire to mic use, I only see 3 wires (3 pins) being used for the mic. I would think you would want to use all 3 wires shielded. Why? B/C I have no idea what each of the wire do (no pinouts). Did you end up using the mic?
Hey Ed.
1. Yes, the added dome lights come on with all four doors being opened (I don't remember if the tailgate turns it on). They do fade out.
2. I honestly don't remember anything about the OEM mic. I replaced it with the mic from my Kenwood because I was having unwanted noise. I just used a mini molex jr to connect the wires I previously had running through a D-sub at the ceiling break. Molex connectors are great!
I literally just got GX console out of storage this weekend to finally install it (bought it few years ago) and was searching for this exact thread. Glad to see it pop back up with a new post. Thanks!Wow, 5 year thread revival!!
Anyway, dont you hate it when a useful thread goes "dark". Anyway, here is what I salvaged from a few years ago.
Sure is pretty
Underside
Here is the plug you will have to splice into (look at the last pic where I drew up what wire goes to what for this to work)
Remnants of the pics that are now gone.
More pics
Diagram of what to connect
So:
On the Console plug, everything is self explanatory except for the last 3 wires.
Yellow:+ 12v for the ambient amber LEDs. Just connect these to a "dash light" wire or however you want.
Black: ground (if I have to explain this, go back to bed)
Blue: This is the "Door open" wire that tells the map lights to turn ON when a door is open. What I'm going to do is fish a wire to the rear map lights. Most do this.
There is another plug that is supposed to plug into a Lexus GX mic circuit, but most don't bother with this (and most don't have the mic on their 4Runner). Don't forget there is a factory mic (mine came with one) where the sunglass holder is. Anyway, I won't bother with it when I install an Android head unit in several months.
Hope this helps!!! Good luck to all (and me, LOL). I'll post pic of any progress and findings I may have.
EDIT: Opps, the pics that are gone are really gone, I can't find those pics that Honda-nos posted. Anyway, he and the truck are long gone. The pictures [MENTION=9622]A/V1[/MENTION] posted are still visible!
Appreciate the tip. I dont remember any fitment/door issues when I did the test fit last year but I'll be sure to cycle it all the way through to make sure. Hoping to install over the next few days so I'll find out soon.I had PMed cookie about more info about the overhead console. After installing it into my rig I found that the sunglasses holder gear was being pushed on by the headliner which not allow it to drop down with spring tension, I had to manually pull it down. I eventually gave up on it after dissecting the overhead console and found a new one with homelink from a local scrap yard for $5 out of a toyota camry that fits.
let me know if you run into the same issue with the sunglass holder not coming down properly.
