Hard to find Specs, Info & Measurements on 231mm 13WL Tundra Calipers & Rotors
Just bought my 2000 T4R. Excited to do this upgrade. Will update with photos!
Only question I have,
When buying the remaned 13WL I realized it does not come with all hardware. (Mounting bolts especially)
I am worried that my current caliper mounting bolts will come up too short. Will my current mounting bolts be long enough to handle the new width of the 13WL, or do I need to get new mounting bolts for the 13WL?
Thanks guys! Great reviews and write ups. Partly the reason I purchased a 4runner finally!
I reused the factory bolts with no issues.
TBU with Powerstop calibers, rotors, and pads, and Stoptech 4Runner stainless lines
How do you like it? I’ve heard the calipers from the kit are 50/50 with leaking right out of the box.
They are fine so far. They are probably just rebuilt and powder coated cores
This is going to be my next upgrade but I'm scared that they won't fit with my wheels! Does anyone know if they will fit in American Racing AR23 16x8 +0 ???
rim question
I still have a steel spare years after doing the 231mm upgrade. I had a flat this Summer, luckily on the rear. However, I have now come across an opportunity to replace this spare with a 4th gen rim with a 265 65 17 mounted. Will this rim fit on my 3rd gen 4R?
I run LTD 16" rims in the Summer with 265 70 16 all seasons and Sequoia 17" rims with 265 65 17 Winters mounted. Both these tire sizes have close to the same diameter.
It would be nice to know if the rims fit on my 4R before I go and look at it... Without having to determine fitment on site! Thanks for any advice.
bump..... comments?
Toyota Parts requiring a Vin # to order the Tundra rotors
Having an issue trying to order the Correct Rotor for this swap. Local Toyota Parts Guy is giving me a problem about ordering the rotor for a 2005 Toyota Tundra 4x4 V-8. He says there are 2 part#s and he needs a vin# to make sure I get the right part. I don't have a tundra, I have a T4R. can someone point me in the right direction?
1st page of the thread shows a picture of the part # 43512-0C011. You're going to spend WAY more locally then you would online.
https://parts.camelbacktoyota.com/p...PONENTS&subgroup=FRONT BRAKES&component=ROTOR
Depends on which of the 4th gen wheels this is. When I tried to put some on mine, the clearance (or lack thereof) between the front upper control arms and the tire inner sidewall on each side made me go get some spacers immediately - I had clearance but so little that sidewall flex could have sent the sidewall into the UCA to be raked and ripped by the UCA. Here's my prior thread on it, hope it helps: http://www.toyota-4runner.org/3rd-g...n-wheel-swap-lug-nut-tire-size-questions.html
There currently is one on Amazon's Warehouse Deals for under $50. There used to be three until a couple minutes ago. :naughty:
https://www.amazon.com/gp/offer-listing/B00KTIFD5U/ref=dp_olp_all_mbc?ie=UTF8&condition=all
Round two of installing my amazon tbu kit after my first set of calipers defective. What were the odds of that? Anyway, just received the new ones but these came with some copper washers...anyone know where they go? Im assuming to the two bolts to mount the caliper.
I just ordered mine - how were your calipers defective?
brendaglores
