Hard to find Specs, Info & Measurements on 231mm 13WL Tundra Calipers & Rotors
I'm wanting to do this upgrade soon, but I have a few questions. Will the 231 fit my stock 16's? I've tried looking for the same wheel but couldn't find anyone else running them. If they don't fit I have no problem getting some 17in wheels but don't know what size KO2's to get where I won't rub w/o getting a lift. Sorry for not starting a new thread but this is my first post and I wasn't allowed to yet.
see the very bottom of post #3 in this thread.
The pictures don’t show up for me when I click any of the links, it said they are lost when redirected to photobucket. Or I’m just an idiot, I’m hoping it’s the dead links and not me ��
the info you seek is in there. you just likely cant see the photos because of the photobucket fall out (i cant see them at work here). but the info you need is where i told you to look.
So, I'm due for some new brake pads and I figured that I would make the upgrade to the TBU. Here's what I've purchased and waiting for. Is there anything I'm missing?
13WL calipers from junkyard $85
OEM caliper rebuild kit 04479-60081 $19.65
2x OEM Rotors 43512-0C011 $145.36
Wagner OEX976 Ceramic High-Perf. Pads $47.87
Stop-Tech Braided Brake Lines 96044007 $49.88
G2 Caliper Paint Kit $52.00
Speedy's TRD Caliper logo $11.00
Wearever Caliper Bolts kit x2 $7.00
Caliper bolt pins x4 $2.00
Brake Cleaner 4x cans $12.00
Brake Grease $3.00
Valveline DOT 3&4 brake fluid (QT) $8.00
Grand Total = $442.76
Obviously there are much cheaper routes I could have gone with but I get to enjoy having a solid OEM + high-performance brake pad combo. The fun of having an older car like a 3rd gen 4runner is you get to rebuild stuff too.
Hi Guys!
So I finally did the 2005 TBU. I went with the 231mm- 13WL
On stock 16" OEM 4-Runner 5-Spoke "Flower" Wheels, found on '01-02 models. I did zero modifications to the wheels or calipers to make it fit.
I've been driving for about an hour; the breaking feels stronger, controllable, bites immediately, and no more gliding to a stop.
There is a little more peddle travel that will take some getting used to.
I've owed the 4Runner over 10 years and should have definitely done this modification a lot earlier.
Parts Used
231mm-13WL Calipers From Auto Zone- C9951(Driver) C9950(Passenger) 89.99x2
OEM Rotors- 43512-0C011 2x$64.37
OEM Brake Pads- 04465-35290 $63.75
Thanks to the 4Runner community for the help, information, guidance, and part numbers. Hope my post helps someone!
Infocus325,
This helps immensely. I have the same rims on my T4R and was having a hard time confirming if the 231's would clear the rim, but you proved they do!
On a side note, how are the Autozone calipers holding up?
Yes, the Tacoma rims fit fine. I’ve run them on 2 rigs with the 231 tundra brakes. Have that exact setup sitting in the driveway now.
I think it would be easier to list the rims that don’t fit.
The only 16” rims I’ve seen not fit were the Stock 4runner split 6 rims.
I’ve run the remanufactured calipers from Oreilly’s on a few rigs with no issues. It’s just shy of $500 to walk into an auto parts store and buy the entire conversion.
But oh so worth every penny.
If you go the reman route open and look at them in the store. Sometimes they will have different bleeder bolts. You want both to have the same bleeder bolt otherwise it’s annoying.
Are you referring me back to the op’s list of “will fit”
yes, post 1142 instructs you to a very specific list. the wheels you seek are one there.
although i will say, its a lot of info to digest over 3 posts. i just know its on the bottom as ive read through the OP a bunch of times.
This is the bottom of Post #3. Where do you see the Tacoma 16" rims model # ALY75189 on that list?
Some info on which wheels will clear the 231mm Tundra Caliper WITHOUT spacers (Just using the quote format to make this stand out):
OEM Wheels that have been confirmed to fit over 231mm Calipers:
17" 6 Spoke FJ Wheels PIC
Base model 4Runner, 6 spoke steel wheels (reference: Wheel fitment with Tundra Brakes - YotaTech Forums)
OEM 4-Runner "5-Star" wheels PIC
OEM 4-Runner 5-Spoke "Flower" Wheels, found on '01-02 models PIC
OEM Tundra/Tacoma 5-Spoke Wheels PIC
OEM 4th Gen 4-Runner 6 Spoke 17" Wheels PIC
TRD Ivan Stewart Wheels PIC
5-Spoke 1st Gen Tundra Alloy Wheels, found on '04-'06 models PIC
16" 2nd Gen Tacoma "Snowflake" TRD Off Road wheels PIC
2017 OEM Trail 7 spoke 17" (Thanks mattray)
FZJ 80 Wheels will NOT fit over 231mm calipers, unless you run at least a 1/4" wheel spacer.
All of these wheels will clear the calipers, according to this thread >>> 16" Wheels and the Tundra Brake Swap - TTORA Forum
16x8 Pro Comp 1059
16" Procomp 8069
17" Procomp 8069
16" Wheeler's Type B
And all of these will clear according to this thread >>>> FJ Crusier Wheels with Tundra Brake Upgrade?? - Page 2 - YotaTech Forums
Ivan Stewart Wheels,
MT Classic
MT Classic II
Procomp 8069
Procomp 8023 in 16x8
Procomp 7089 17"
FJ 5-spoke (with spacers)
Weld Racing Renegade
The following wheels have been confirmed to clear 231mm calipers by T4R.org members. Do a search for their builds/posts if you want to see some pictures.
17x8 König Countersteer Type-X (Thanks, 4Ripcord)
16x8 Sidewinder wheel by Weld Racing Wheels (Thanks, Dmart 808)
16x8.5 Level 8 Strike 6 Wheels (Thanks, Tylerbaird & Blcktpgsr)
16x8 Vision 375 Warrior Wheels (Thanks, theizzardking)
17x8.5 Stealth Custom Series "Stealth 6" (Thanks, SCS...SCS's T4R.org Sponsor Sub-Forum)
16x8 Stealth Custom Series "F-5" (Thanks, SCS)
17" Pro-Comp 7005 w/4.5" BS, 10mm offset (Thanks, foxrider)
16" Jaos Excel Pro II (Thanks kymo & semcoinc)
American Racing AR23 16x8 (Thanks houndrunner)
16" Raceline Rockcrushers 4.5 BS (Thanks Tigran)
Any others that people know of? Send me a PM and I'll add them to the list!! Thanks!
16x8 Pro Comp 1059
16" Procomp 8069
17" Procomp 8069
MT Classic
MT Classic II
Procomp 8069
Procomp 7089 17"
see bold.
edit: i cant see pics here at work, but i looked it up via a google search and i got what came up in post 1148. i looked up the picture on post 3 on my phone and it looks like its something different. i apologize.
see bold.
The person was asking about 3rd Gen Tacoma rims per his picture.
The Bold is the 2nd Gen Tacoma rims (2005-2015).
i googled the bold text (because i cant see the img gur pics here at work) and i got more results of the of the picture he posted. that is why i said it was on post 3 cause i was assuming google was right.
Bump
Hello, first time post for these forums. I've spent the last couple of days reading the wealth of information in this thread. I have not seen if anyone is running the sr tacoma wheels with the 231mm calipers.
Does anyone on here have experience with these wheels and the tundra brake upgrade without spacers?
Any input would be appreciated try to figure this out before I get new tires.
Any luck with the Gen 3 Tacoma Wheels?
Bump
Any luck? I was looking at a set too.
youngrk
