Height measurement needed
Mgltacoma
I do not have access to my truck for a long time. I need to get it shipped to me, but I need to know the exact height of the vehicle since I am in apartment complex with low clearance parking. My truck has 3 inch lift Icon stage 2 lift with Duratrac 33" tires with Konig 6 shooter 17 inch wheel. I do not have a roof rack(just standard rack it came with) It is a 2016 sr5. My setup should be fairly common, hopefully someone can help me to get the exact height. Any help will be appreciated. Thanks in advance.
Mine as a point of reference is exactly 73" to the tip of the shark fin. Measured on flat garage floot using tape measure and 4ft level.
No lift on mine. 275/55-20's on stock SR5 (see sig pic)
Not an exact answer, but I will mention if you are running a stock radio antenna it is a few inches taller than your vehicle. I park in a low garage at work. My antenna whacks multiple beams that easily clear my stock rack.
I'm at work or I'd measure mine. My parking garage has a 7ft clearance. I have the same lift set to 3inches. I have bfg k02 285/70R17. Mine fits in the garage with a few inches to spare.
Cpn2mss
