Alrighty.. This weekend I FINALLY get to run some wires. I finished the fabrication of my Aux fuse box brackets and painted it so I should be all ready to go.
When researching that I had an appropriate size wire to run from the battery to the fusebox I came across the below schematic:
So the two questions for the evening:
1) What gauge wire should I run between the battery and the positive bus on the fusebox?
2) Should I head down to autozone and pick up relay and an inline fuse?
2a) If I need the inline fuse, should it be a 20amp when the fuse for my 4 Hella lights is a 30amp? makes no sense to me to have the battery connection go out before the fusebox?
The fuzebox is:
Product ID: 5025B
Blue Seas ST Blade Fuse Block With Cover
6 position with negative bus
Clear insulating cover with label recesses accept Small Format Labels
Cover Satisfies ABYC/USCG requirements for insulation
Tin-plated copper buses and fuse clips give 30 Amperes rating per circuit
Accepts ATO and ATC fast acting blade fuses
OEM version, labels not included
Height 3.315 inches
Width 4.894 inches
I also just got my invoice from Gobi, so the rack is on it's way!
Okki
