dustin Keeler
Member
Ok, please don't flog me as I searched for two days on what to do on my rig. Tried lots of things and still not right.
History is: 2000 model with 190k and I wanted to have the valve cover gaskets changed because it was leaking pretty bad. I had an ASE certified friend change them for me since I was covered up with my job. I have not had a single problem before doing the gaskets and now......
I'm getting a misfire in cylinder #1. I have tried new plugs (properly gapped), wires and coil boots. None of which helped out. I have tried putting fuel injector cleaner thru it with no help. I've tried swapping out the #1 coil with the #3 and still get a misfire in cylinder #1. The rig starts and runs fine when I first start it in the morning. I then go to the store and get a drink or bfast and when I start it back up, it will be missing. Sometimes the engine light is on and sometimes it's not. If it's not missing then I can drive it for a full hour and it won't have any issues but once I shut it off, it starts missing all over again.
Please help me. Possible fuel injector?
