HELP! Tire issue Rubbing
PearlWhite4R
I just got my 285/70/17 with MK6 -12mm offsets installed. Im having major rubbing issues. I have a 2014 limited. I cut the back part of the wheel well off (the part holding the "mud flap') and I'm getting rubbing in the front and the tire hits the metal (too dark and tired to investigate more tonight). Also, these are Terra Grapplers. Any help appreciated.
How much lift did you add? Just installed same tires, no additional offset . . . No problems.
I'm guessing you are rubbing the front liner and body mount? Moving the liner forward is easy and then you may need a body mount chop.
I just installed 285-70/17 terra grapplers installed and had to remove the front mud flaps and move the fender liners forward. I still have to trim the drivers side part of the bumper in the fender well. That's the only part I have any issues still. I have a 2.5" lift and method nv 17x8.5" wheels with 4.5 back spacing. Hope this helps
Here's hoping you've got at least a couple inches of lift under your truck and upper control arms that will allow you to put some extra caster into your alignment.
Ok so heres an update. Im mainly rubbing the metal from the wheel well on the back side where it wraps around. Im going to attach pics. I measured from the middle of the wheel to the bottom of the wheel well and I'm at 23" now. It is rubbing rubber though and its just on regular roads. Toytec thinks they may have done the alignment wrong with the LR UCA's.
Limited must have different set-up. My Trail with KDSS has no rub with those tires only slight plastic chirp while reversing and wheels at fool lock. Nothing major. Sry for all your troubles.
You shouldn't need a BMC with the 33" tires and correct offset wheels you have. I'm with Toytec that the LR UCA's were set up wrong. Probably set them up at the -2 setting or more instead of 0 to begin with. That would push the wheel back as a starting point . They already have -2 built in at zero.
SPC logo should face outward!Let's see pics of the the LR's
I think the only width those wheels are available in -12 offset is 9". If so, a 9" wide -12 offset wheel is pretty aggressive. You would rub a bit more than someone with a 8" 0 offset or 8" -10 offset wheel would.
Holy SH!T man. They ordered the wrong wheels. They got the 17x9 and not 17x8. I can't believe I didn't catch that.
Umm ,They installed them up side down!!!
But seriously ,those LR UCA's top cams actually look like they were set right.
Do you know what they actually set your alignment to? especially the caster setting?The higher the caster setting the more it moves the wheel forward in the wheel well and thus less rubbing in the back.Easy to adjust the front liner so it doesn't rub there .Specs are 2.2 to 4.0 with getting the camber real close to 0 but alot of us are running 5 or more and still get 0 on camber and what I prefer.
Here's some reading on alignment....http://www.toyota-4runner.org/5th-gen-t4rs/115173-lift-installed-alignment-help-please.html
http://www.toyota-4runner.org/5th-gen-t4rs/118899-alignment-spec-minimal-fender-rub.html
http://www.toyota-4runner.org/5th-gen-t4rs/120963-alignment-question.html
Plenty of people on here running those 9 inch wide wheels with -12 offset that haven't needed a BMC with 33's(285/70/17).I didn't do a BMC til I went to 34's but I did cut out a part of that rubber TE mud flap that was rubbing with an exacto knife. Easy to tell where it rubs as the tire leaves tell-tale marks.
I'm running 18x9 -12 with 295/65/18 and did not need a BMC. I agree that a new alignment should fix your issue. I did have to trim a bit and push the fender liner forward but nothing too extreme.
