4ever4running
My accessories are beginning to pile up so I have been looking into getting a Blue Sea fuse Block to help clean up some of the wiring. My main question is: Do you need some sort of a breaker/larger fuse between the battery and the fuse block? I have done some research and browsed through some threads and some guys used them and some didn't so I didn't find a definitive answer.
I am going to go with either this 6 circuit block:
OTRATTW
OR this 12 circuit block:
OTRATTW
For reference, here are the accessories that I either have or am planning to have running through the fuse block:
4 - PIAA 520 ATPs (85W each, 2 relays wired together)
2 - PIAA 510 Crystal Ion Fogs (55W each, 1 relay)
2 - Hella Rallye 4000 (100W each, 1 relay)
1 - Viair 400C Air Compressor (Power from battery to on/off switch)
Finally, does anyone have any pictures of a Blue Sea fuse block mounted in a 3rd gen?
OTRATTW
OTRATTW
