Here's Some Help with Navigation Install
New pics!
See the Orange light thread for LED pics
The above pics are with the new face plate I posted earlier in this thread.
webshot said:
Just tried the monitor thing and i could not get it to work FYI.
All the Sienna guys have the stock rear DVD system with a separate ECU for it. The ECU sends out the signal to activate the monitor feature. Your all willing to give it a try though. maybe you can figure it out. I could not.
WebShot...I have been researching this also at the Sienna Site and was wondering if the ECU is a part that can be ordered and made to work. I am very interested in getting some video upfront so I can set up the DVDs for the kids. I have an external DVD player and headrest monitors.
Also interested in the backup camera. Can it be purchased from the dealer. Part #
1 more thing the trim piece to fill in the gap...What is the part # if I wanted order the Limited center piece or is there someone who would like to make one for me that looks factory...
Backup camera
Dealer wants $460+ for the Toyota oem backup camera.:eek:
We have been experimenting with others. Savv makes one that closely resembles the factory OEM unit. I got one of those cheap ebay specials coming to test with as well. Apparently anything that outputs NTSC signal would work. This also creates another interesting scenario. If you can't use the 6pin blue plug to input external video, you can use pin1 and 3 on the 4pin white plug next to it which works with NTSC backup camera. Only thing you have to do is figure out how to trick the nav into thinking you are in reverse gear.
Stephen
It could be specific to the Sienna version. The 4Runner version does not display anything but the backup camera image.
Mike
I'm thinking that the "check surroundings for safety" text on the screen from the Siennaclub image is because the guy is right behind the camera and up against the bumper--maybe the camera and the "brains of the unit" can detect that there is an object right up against the back of the vehicle?
-Jason
I don't know the part numbers for any of that stuff, sorry. There is a thread on this forum about the backup camera and I think Gregtay posted a part number for it.
If your going to purchase the correct enitre center console peice for the nav unit, You will need the one with the smaller opening. Some sport, and SR5 models come wth this console. I believe the price for the peice is like $400 or somehting insane like that. Thats why I made my own face plate for $5! The Limited center dash peice is what I have, my 4runner is a limited. I believe there is also another post by jomama in this very thread that might metion the part number for it.
Good luck,
That "check surroundings for safety" text is in the Solara/Camery nav, and also on the Lexus RX330. It's always there regardless if you have video or not. I was getting it just by shorting the camera input (so nav knows something is connected), and shift into reverse gear.
We got the RES DVD video to play in the nav through the ECU. However the video would shift back to nav map as soon as the car starts moving. So grounding the parking brake alone does not do the trick. Need to add a timer to periodically disengage vss to fool the nav into thinking vehicle is stationary.
Stephen
I am having more troubles with my install than I had hoped. I finally got the GPS signal straight. There must be something in my dash that the GPS antenna doesn't like because when I mount it above my rearview mirror, I received GPS signal 99% of the time as compared to 9% of the time.
The hopefully last challenge has been the am/fm reception. I thought I saw a post earlier that for a 2004 4runner without JBL, this wouldn't be an issue. On mine, it is an issue. I tried both Pete's approach in his instructions and OEM revised approach. (tap and connect grey and black wires from 10=pin plug that was originally in the factory head that is now attached to the jumper harness)
Any suggestions would be greatly appreciated.
Original windshield. I'm not sure why I had such an improvement in GPS signal from under dash to just above rear view mirror.
As for the antenna amp, I'm getting frustrated. It sounded like the reverse and speed wires were the more challenging items but those didn't seem to give me any troubles. On the other hand, neither of the 2 antenna options posted have worked for me.
Is there another way to try and get power to the antenna amp?
It's likely an ISP or server issue... the domain registration doesn't expire until August according to the "whois" I just ran... I'm guessing Troy is just changing web hosting providers, since a place holder for globat.com shows up.. and whois shows a different hosting company on record. (ie; it hasn't gone thru yet)
It's back up with a message saying it'll be down a 4/27-31 for construction.
I didn't know there are 31 days in April, but that's besides the point.
Stephen
