HID Install for 2006 4Ruunner
Updates on HID's
Any updates on problems with HID conversions on 4th generations? Still lasting? Losing light output etc? Any suggestions on new kits or new methods of installing it? Thanks.
Im on my 2nd set for 4R #2 and not one problem. Love em
No problems with mine. Added fogs about a year ago. Both kits came from Xenon Depot.
I think I will go for it. So no need to readjust lights or mess with squirrel finders right? Just plug and play? Thanks for the input.
It's plug and play. Depending on the aim from the factory, you might need to aim down as HIDs are a lot brighter and will cause other drivers to flash you. Modding (pushing) the squirrel finder (tab forward) will help clean up the cut off and eliminate some glare, not all of it.
My suggestion would be do the plug and play, upgrading to HID. Drive around for a few days (well nights) and see what type of reaction you get from other on-coming drivers. I've had people in SUVs and trucks flash me, but most folks in cars don't even notice. I probably get flashed about 2-3% of the time, not enough IMO to be of a concern.
Did you have to adjust the squirrel finders and reaim the headlights?
To be honest, I have noticed cadillac escalades and acura TL's factory HID's are frickin blinding! and they are FACTORY!
I agree. I would suggest installing the kit before making any modifications. A lot of our customers do not modify the squirrel spotters.
Steve
Did you do a retro fit on your 4runner or did you use the stock projectors? Did you eliminate squirrel finders? Thanks.
Stock projectors, left the squirrel finders alone. I don't get flashed often, and when I do, it's more from other SUVs/trucks than cars.
After reading through 4RunnerRon's write-up, I am left a bit confused.
I received my Xtreme HID Kit today and I noticed that I have not one (1) but two (2) Relay Harnesses that are included. When comparing the instructions provided with the kit to those provided by 4RunnerRon, there seems to be a difference in that unlike 4RunnerRon, the passenger side headlight connector will be used instead of sealed with electrical tape.
Has anyone else installed a kit recently that has two relays? And if so, am I correct?
I believe that is correct. I think it was a production change sometime. I also just received mine (install not finished) and that is the way mine is too (uses both factory harnesses - one for each ballast / relay). I like this better than the original design.
XenonDepot-
What kit would I get for a 2009 4Runner? If I wanted to get the fog lights to match the color, what kit would you recommend?
Thanks.
patnewton
