HODOR's build and Adventures
Looks awesome with all the bolt-ons attached !...
I can take a look at the can holder during your off season... Just drop the box assembly and cans here when your not in need of them...
correct me if I'm wrong, but the way you mounted the drawer slides for the fridge is not oriented the way they are supposed to be. Those heavy duty slides are meant to be side mounted. Undermount (or bottom mounted) drawer slides are built different and usually not as strong. The max undermount slides I've seen were rated for 120lbs.
If those are indeed undermount 500 lbs slides please let me know where you found them. I have been doing some research lately trying to find undermounts that are strong enough but have been unable to do so.
EDIT: in the earlier pics it looked like it was mounted wrong. Now you used side mounts. Either way I'm still interested.
You are correct that's why I redesigned the drawers and bought actual fridge slide
Had an awesome time exploring VT last weekend. We visited Alchemist Brewery, went to see the caves, a waterfall, pick apples and climb a hill or two.
Meat fest
Most delicious IPA
In preparation for winter I coated everything under and bumpers with Fluid Film. Have been doing this every fall since new and it works like a charm.
I'm going to be honest, I read through your thread again haha! I'm amazed because you have the exact front bumper, rear bumper, tires, and roof rack! Lol. Now I have a few more questions I hope you don't mind.
The switch from steel to aluminum in the front. Any worries about how strong the aluminum is, especially at recovery points where there is a lot of force? If you hit a tree with the steel, it probably wouldn't matter but what about with the aluminum. Would it dent?
Fluid film!! I just bought some but been hesitant to use it. Do you spray everything underneath or what do you avoid? Does it make it messy and slippery to work on? Would it hurt paint? The bottle says it may soften a vehicles undercoating, what are your thoughts on that?
Last question...for now lol. What's your Instagram??
2015 bumper
Hello,
Im trying to construct a bumper that mirrors a 2004 limited 4runner with the rear fog lights integrated in the bumper. What do you think about that? or do they sell such a pretty beast like that??
I like your pics of your 4Runner!
Hi [MENTION=134723]kSteven813[/MENTION]
So far it's holding up good (I had some minor run ins with the trees lol) weight savings is incredible as well. No doubt steel is much stronger than aluminum, I winched few times and so far no signs of stress.
Fluid film atomizes so you might want to wear a protective suit and a mask (I wear coveralls and safety glasses). I spray with the small hose inside the frame rails and regular nozzle all over everything under. It doesn't hurt anything, it can get on your windows and paint but that's easy to wash off.
Lipek1229
I hope I his answers your questions
Karol
Lipek1229
Karol
Yes, thank you! Awesome Instagram btw [emoji1303]
Oh, does the fluid film make it messy/oily to work underneath?
Hello,
Take a look at [MENTION=79132]Nyc-Runner[/MENTION] build he might be able to help you out with your 4th gen.
Thanks man
Not messy but oily lol I don't usually work under there during winters so I don't mind, by the spring it's just a thin layer left almost not noticeable.
Great post! Thanks for the info on mods to where you have been.
I'm from California, now living in PA. Still prefer the "wide open space"; but pleased to see there are places to go here in the East.
Thanks man
Did you go with aluminum skid plates?
[MENTION=134723]kSteven813[/MENTION] I did not, having aluminum skids on my FJ before I thought I'd give steel a chance and so far I'm pleased with results.
Bumper looks good bud! I like those lights in the sides, do you have them patched in to your reverse lights? I'm probably going to add them to mine and have them connected to my reverse but also run to a separate switch as well!
Bummed we didn't get to catch up with you guys up in VT! You have any other trips planned before it starts to snow:smow:
[MENTION=79132]Nyc-Runner[/MENTION] thanks man, the flushed back lights are connected to the reverse lights but the little side steps lights are on separate switch only. I'd like to connect my reverse lights to on demand in the future.
I started my new assignment on recruiting and working like a mad man. I'm planning to make turkey trot.
matisgugle
