How to Chabge Chevron Arrow Bulb
Run4nuts
My side view mirror “Chevron Arrow” turn signal is burned out ...I have a 08 4R Limited. I can’t seem to find any instructions on how to change this bulb. Can someone point me to a instructional video for this?
Can you take a pic of this? If it’s what I’m thinking, it’s muth signal mirrors, which is not OEM equipment. If that’s accurate, those are LEDs I’m pretty sure and not replaceable. Maybe you’re lucky and it’s a loose wire/ground. But if not, you probably need to replace the mirror.
Is this it? shop.muthco.com/4-runner-signal-mirror
Thank you for the reply. You are correct they do say Muth Mirrors... this makes may be a Toyota “port side” modification as it’s a limited edition. do you, by chance, know how to remove the mirror so the wiring can be checked?
I have a limited as well, and I don’t think I’ve ever seen this as a port add on. But maybe. I installed these on my last 4runner and I went with a different version for my current 4Runner.
If you go to the site I linked, they have a PDF on how to install it. It covers everything, and I used it to install my new turn signal mirror covers that I currently use.
