Did you already try flipping the LED? The diodes are directional, so if you have them hooked up backwards, they wont light up.
I wasn't aware of that. By flipping, do you mean taking it out, turning it 180 degrees, and reinserting it? That would seem to be my only option.
I got all the others to work properly on the first try - was I that lucky?!
I replaced the LED's in my HVAC cluster but the middle knob is dark. The OEM bulb went out a few days ago.
I tried multiple LED's there, so I know that's not the problem. What could prevent the LED from lighting? Bad contacts on the board?
now you just need to solder LEDs for the arrows and indicators!!
These are the ones I used. The screen uses 4mm, everything else uses 3mm. Straight swap, once you get the diodes in the right place!![]()
The diodes are directional, so if you have them hooked up backwards![]()
Any chance you have a wright up for the dash/gauges?
You. friggin. rock.. lol I think the stock lights need an update lol
Thanks, but the real credit goes to [MENTION=20116]darkie3495[/MENTION] :cheers: I'm just glad I happened to remember the thread lol Good Luck and post pics when you are done :becky:
