I found "The One", 2001 Sport Ed. TRD SC'd
Big Fish, huh? :fishing:
Just messing with you. Rig looks great as always and the trips it's taking you on are priceless!
Thanks man, the trips with the family are the best. I can't wait to take my little girl to Moab. I think next year she'll be ready.
BTW, you must have missed the picture of that piggy rainbow a little earlier in my post... I'm not fishing as much these days, but I can still do justice to my forum moniker.
Hey BFAD... which dome lights did you end up using? I didn't see it mentioned (or I missed it). I bought the Thin Flexible 5MM ones from Oznium and I'm returning them, they aren't as bright as I had hoped. Looking for something brighter.
The dome lights in the pictures are these ones (24 LED, $4 on Ebay):
1x T10 Festoon Universal 24 SMD Xenon White LED Panel Interior Dome Map Light | eBay
I'm happy with them, as they are much brighter than stock bulbs, but I still want more light, so I ordered some of these (48 LED, $2.50 ea if you buy 5):
5X 12V Car 48 SMD White LED Light Panel T10 Festoon BA9S Dome Adapter US | eBay
I'm hoping the 48 LED panels will satisfy my desire for more interior light. They are cheaper than the 24 LED panels, so I'm not sure if that's an indicator of quality or not. We'll see.
The up side is that the 48 LED panels come with BA9s bulb adapters, so I can run them in the map lights too. The 24 LED panels only came with festoon and T10 adapters. Having the BA9s adapters also allows me to move the 24 LED panels to the map lights in case the 48 LED panels don't fit.
I also bought these BA9s 12 LED bulbs for the map lights, but as I mentioned before, they weren't even as bright as the stock incandescent bulbs.
6pcs BA9S 10 SMD Xenon White High Power LED Light Bulb Car Van Truck DC 12V Lamp | eBay
Great pics as usual man!
I almost ran Kane Creek when I was in Moab in June but ended up going on a lighter trail for our last day.
While on Kane Creek did you get scratched up much by bushes?
I had two people tell me to expect lots of hard scratches along the side of my truck if I ran it. That was pretty concerning but because of a change in plans I didn't get to see for myself.
I really don't mind the an occasional light mark here or there but deep scratches suck big time on black paint.
You should have done it! It's a fun trail. You'll definitely get some pinstriping, but it's not too bad. If you drive carefully, you can usually avoid the bigger branches that stick out and leave the really deep scratches.
The tricky part is that the trail changes every year due to erosion in the creek bed. There were sections this year where we had to pass through thick groves of trees/bushes that had just recently been cleared (by machete as far as I could tell). Those sections were pretty tight, and left their marks.
I meant to post this info as part of my last update, but the forum was having some issues that prevented me from editing an earlier post.....
After installing all the new front end parts, I performed an alignment in the garage using a level, a square, and a measuring tape. I'm developing a method that works surprisingly well, as evidenced by the "before measurements" when I took the rig in for an alignment...
Left Front:
Camber at -0.2 degrees
Caster at 4.6 degrees
Toe at 0.29 degrees
Right Front:
Camber at -0.5 degrees
Caster at 2.9 degrees
Toe at 0.15 degrees
2_zps2f8a05a6.jpg~original
I was almost dead on with the camber and toe on both sides... just a little bit out of spec on the LF toe. The funny thing to me was that I had the LR UCA's set to the same position on both sides (+2.0 degrees camber, setting "D", I believe), and had the eccentric cams on the LCA's set to the same position on both sides, yet the caster was 1.7 degrees off from side to side. I set it up per the LR instructions for maximum tire clearance, with the cams on the LCA's set for max caster. The front cam on both sides was maxed inward, and the rear cam on both sides was maxed outward.
I asked my alignment guy about that, and he said that he has seen that variance in many of the Toyotas that come through, but could only guess as to why it exists. The good thing about the way I gave it to him was that he had plenty of room to take caster OUT of the setup, and play with camber via the LCA's, which is what I intended. Here's where we ended up:
Left Front:
Camber at -0.1 degrees
Caster at 2.6 degrees
Toe at 0.01 degrees
Right Front:
Toe at 0.02 degrees
1_zps07cb25b2.jpg~original
So now my alignment is perfect, and the '01 feels like it should going down the road. I'm so happy to have some caster back in my setup that I'd buy the LR UCA's all over again for that benefit alone. I can actually take my hand off the wheel on the highway without the rig trying to veer off to one side or the other... it just tracks nice and straight, right where I point it.
Just for reference, the factory alignment specs are:
Camber: 0.5 to -1.0 degrees
Caster: 2.3 to 3.8 degrees
Toe: 0.00 to 0.20 degrees
Hey BFAD! Try posting now. I tested it thoroughly and haven't encountered issues the last few times I tried it.
I just tried it again and it wouldn't work, but I got to looking at the post and I think I figured out what the issue was... I changed some things around within the post itself, and it went right through. I'll PM you with the details.
Thank you for looking into the problem, I really appreciate it. You're the man, so I threw some "rep" your way. It's the least I could do.
Chokecherry & the San Juans
I met up with [MENTION=95069]TBuzz[/MENTION] last weekend for some wheeling, fishing, and camping. He was kind enough to show me around his neck of the woods and put me on some good fish. Thanks again, Chris.
We started off Saturday morning at Chokecherry, and within 2 hours we'd hit a bunch of obstacles. The place is pretty awesome, and although I only saw a fraction of it, there were several obstacles in that small portion that I was not ready to attempt. You can go as big as you want at this place... up to and including demolishing your rig.
10 minutes in, we found a flexy spot and got a chance to check various clearances on our rigs. (notice the difference in the gap from side to side between the body and the ARB front in the pics below... just another illustration of how much the body can move in relation to the frame on these things)
32_zpsba7c62fa.jpg~original
Front passenger, hanging on the strap...
30_zps797affae.jpg~original
Time to stuff the other side...
29_zpsf51f1e12.jpg~original
I'm pretty happy with my setup. Everything tucks up nice and clean. I have some minimal rubbing in the front, and the driveshaft contacts the gas tank skid just a little bit at full stuff. Otherwise it's about as good as it gets, IMO.
Moving on... we went down stuff.
IMG_0968_zps074f286d.jpg~original
And we went up stuff.
27_zpseb64c4f0.jpg~original
Got this climb on video...
IMG_0986_zps8f5ffa44.jpg~original
IMG_0994_zps6e982134.jpg~original
26_zps212cf660.jpg~original
25_zps7a972d65.jpg~original
TBuzz started having some steering issues, so we decided to wrap it up before something broke out there.
We got some eats at Zia Taqueria and checked out some fishing spots on the Animas before stopping at TBuzz's house to grab some gear. Then we were off to the high country.
Saw some "mountain maggots" along the way.
22_zpsf80e2332.jpg~original
Found a good campsite...
2_zpsf47332c7.jpg~original
We made our way up to a body of water, and found a few of these waiting for us...
4_zpsce2b5654.jpg~original
21_zps68e30adf.jpg~original
I caught a nice one, and broke off a few more before we went back to camp. In the morning, we got some more slime on our hands.
15_zps8339c84a.jpg~original
Gotta love getting high!
12_zpsffbb532b.jpg~original
11_zps5df6729a.jpg~original
TBuzz took some short video clips of my rig on some obstacles at Chokecherry. If you hit the play button below it will play through them in series.
Hey Nick, did you take pics or measurements before installing the new UCAs? I'm curious how much clearance you gained.
I was on a mission installing those things, so I didn't take any "before" pictures. I can tell you that I gained about an inch of clearance between the UBJ and the coil spring at full droop, and even more at ride height.
The major difference is in how the ball joint mounts to the UCA on the LR arms versus stock. On the factory setup the stem of the ball joint goes UP into the UCA, but on the LR arms, the stem of the ball joint is on the bottom and goes down into the adapter that is pressed into the knuckle. Also, once installed, the ball of the stock UBJ basically sits within the top of the knuckle, where the LR UBJ sits entirely below the UCA.
The overall effect is that the UCA sits at a much better angle because the LR balljoint is not only taller, but mounts differently. The LR UCA is more/less flat at ride height, where the stock UCA was sitting at a downward angle (probably 20 degrees or so) putting the UBJ closer to the coil at all times.
Looks like some good wheeling! How much do you rub in the rear at full stuff?
Zip. Zero. Zilch. Nada. Not at all.
I could put 35's on the rear today and have only minimal issues.
Glad you made it that was a lot of fun. Slickrock wheeling at 5000 feet then chasing cutty's and camping at 12,000 in the same day wasn't bad at all. I look forward to next time, maybe when Natemob gets back and it cools off a bit.
Heck yeah, Chris. Too bad we broke your rig, but it's going to result in some serious upgrades. I'm looking forward to checking out the new additions next time we head out.
I didn't even think about it, but dang... we did gain 7000+ feet of elevation on that drive up on Saturday.
[MENTION=88391]NateMob[/MENTION] , what do you say?
Awesome upgrades are in Chris' future, you are right about that!
Regarding me joining up with you guys, Oh Hell Yeah! :jump: That looks awesome and i think you know those trails are right up my alley, I cant wait to be back and making up for lost time. I've got a garage full of upgrades waiting for me also! Wrench Day?
I'm looking forward to you being back, Nate. It's a long drive up to Chokecherry for you, so maybe we can make a two day trip up there once things cool down (this fall). I'd be game for a wrench day. I think Chris' rig will be all buttoned up by the time you get back though, he was down at my house today picking up a final piece of the puzzle.
What do you do for work that allows you to take all of these amazing trips? I'm super jealous.
Have you ever thought of switching up your suspension? You've been upgrading just about everything else, but you've kept the same suspension, besides switching to the Tokico's and rear coils. Your set up is pretty basic as far as suspension goes (Bilsteins and Tokico) and I'm sure you could get some more travel and performance out of a rebuildable coilover and rear shocks. I'm assuming you have the mind set of if it isn't broke and works, then why replace it.
I'm a professional dodgeball player.
Not really. I work shifts on a 6 week rotation and I end up with 19 days off out of every 42 (w/7 of them being consecutive). That works out to about 165 days off each year BEFORE I take any vacation. It costs me 32 hours of vacation for two weeks off if I play my cards right, so you can see how I end up with a lot of time off work. But as you know, with a kiddo, every second of that time off counts.
RE the suspension... The short answer is that I'm happy with what I have. It meets my needs... It flexes very well (see pictures in my last trip report), it rides great, it supports the loads that I carry, it doesn't require maintenance, it's warrantied, and last but not least it's already installed and tuned about as perfectly as it can be.
No offense to anyone, but I think that an outrageous suspension is a waste of money in most cases. 90% of the people who install them will never use them anywhere close to their full potential. Granted, if I won the lottery I'd install a suspension like [MENTION=64995]Patio Burrito[/MENTION] has and call it a day. It's a work of art. But for my needs it is WAAAAAYYYYYYYYYY overboard. I don't drive fast enough to use all that stuff. I drive really slowly over big ass rocks. All I need is flex and enough spring to support the load, with a comfortable ride on the street.
Not everybody wants to switch their suspension and tires every 3 weeks robert :P
Oh yeah, and this too.
Plus, even though I check craigslist every day that I'm within reach of a computer, morning and night, I never find deals like the ones you find.
That sounds like a nice schedule and especially with a kid. I'd love to have more than two days at a time to spend with the family and do anything I want to do on top of that. You're a lucky man and you have a lucky daughter. I hate Monday mornings when my daughter asks where I'm going and I tell her work and she gets all bummed out.
I figured that was the case with the suspension. It seems like you have worked out a lot of the kinks and is set up perfectly for you. Only reason I asked is because my FOX's are extremely better than my old bilsteins and Eibachs and Tundra/Bilsteins up front. I didn't think it would be that much more noticeable, but it really is. I agree people go way off the deep end with resi's, secondary shocks, ect. just to get the groceries (not saying Patio Burrito is that guy at all, just a general example of other rigs I've seen).
I've definitely spent quite a bit of searching to find my deals and the FOX's were way to good to pass up. Helped the guy was 5 min from my work and after selling some other deals I found they ended up costing me nothing. Well keep up the great work and raising a beautiful daughter.
PS... turn up the volume so you can hear that exhaust note :biggrin1:
I could look at these pictures and videos all day.
The look, sound, and performance are spot on.
matisgugle
