BigFishAllDay
Alright... lots of work getting done, and lots of catching up to do. I'll try to keep this brief...
First, I snapped the breather tube off my ADD actuator while taking apart the ADD system. So, I picked up some brass tubing and sleeved it for reinforcement, then stuck it all together with some epoxy.
I recently discovered that the neck snapped off almost entirely on the factory airbox. I assume this is due to the 1/2" body lift combined with the limited flexibility in the AIRAID MIT tube. I removed it and attempted a repair with epoxy, but I can tell it is still flexing and will eventually crack again.
Well, I recently removed the AFE intake from my Tacoma to deal with some issues I was having tuning it in higher gears at high RPMs. The Tacoma is running much better with a stock airbox, so the AFE was just sitting around. I figured why not? This is the setup with the Pro-Dry S oil-less filter, which got a thorough cleaning prior to install.
I had the P/S CV support bearing pressed onto the intermediate shaft by my mechanic, and re-assembled the ADD tube with all new seals/o-rings.
While I was re-spooling the line after winching out of my situation, I realized that while my in-cab controls are nice, I need something that will let me control the winch from outside of the vehicle. I had a plug in for the remote located in the DS footwell when I was running the Smittybilt, but have not set up a plug in connection for the wired controller on the new Warn. The plug for the Warn isn't as easy to relocate as the Smittybilt, so I went wireless.
These things are $15 on Amazon and work great. I extended the antenna wire by 5 feet so it has great range and very little delay in switching the winch on/off.
I located the receiver behind the fuse box with 3M double sided tape.
While piggybacking the wiring, I cleaned everything up with quick disconnects for the winch control wiring to the cab/wireless box.
Last week ECGS shipped my diff back (more on that later), so I started getting ready to reassemble and install. Well, I got to looking at my stub shaft and I'm glad I did... notice anything funny?
Look CLOSER... Twisted splines and stress cracks all around. This would have let go on the next hard obstacle I ran, making for MORE fun. Thank goodness I caught it.
I have a spare on hand, but it has some mileage on it, and I really don't want to do this again soon, so I ordered a new one. It arrived today, so the diff will go back in over the weekend.
The LCA mount on the frame has been fully straightened (as best I could), welded, and re-painted. I welded the alignment cam tab and a few other small cracks in surrounding welds that resulted from the bending of the bracket.
Afterward I hung the DS LCA, installed the new alignment hardware, and painted the crossmember.
The old arms got a thorough cleaning, a new paint job, and a fresh set of Whiteline LCA bushings. These are ready to install and will likely be for sale, so if anyone is interested, send me a PM.
A comparison shot of Whitelines vs. OEM bushings...
