I got rubbage
Ahh , I'm 7harper now. Still can't log into my harper7 account:fishing: I know... We've got a whole list for him.
Thinkin' the gators done ate gatorgreg!!lol
A real pain for me when I had spacers/adapters on is my local Discount Tire said they were some kind of liabilty and would'nt put wheels on them. I have heard that. I have also heard some places that won't do spacers but working with Spidertrax, once explained, is ok. It would be inconvenient as heck to have to go through that hassle every time you wanted tire work done.:cry: So when I went to recheck balance I had to take them off first and then put them back on at home.
:cheers:
Ok. Here's a twist. I looked up the wrong specs for the wheel's or at least i hope. They make two different types of 20x9. The one mentioned earlier and this one.
Backset 4.53
Offset -12mm
How does this make a difference and what can or can't i do now.
Wheels
Backset 4.53
Offset -12mm
Backset 4.53
Offset -12mm
That sounds more like it!
The 5.71 backspacing would definitely rub on you UCA's.
You can get a 3/2 lift and have some minor front trimming.
Or you can get the Terra Grapplers in a 275/55/20 like most people and have no rubbing.
275/60/20 is a 32.99 inch diameter tire / needs lift and trim
275/55/20 is a 31.80 inch tire/perfect fit
Nitto Tire - High Performance Tires for Car and Truck Enthusiasts
Harper
what type/size of lift do you have
Right now I have a Toytec 2 inch front spacer lift.
I'm putting on Icon coilovers and rear shocks for a 3/2 lift.
UPS lost my rear shocks though. Long story short .....They say they were delivered to my front porch last Friday but they were not and it was insured and supposed to be sig .required which they don't have proof of. And UPS has to communicate thru Demello where I bought them as they are the shipper. Always something !
My suggestion is either get a front leveling kit, or put a set of 275/55/20 tires since that is the closest size to stock.
As for offset/backspacing issue..... I have little advice to share since I cant seem to find a straight answer on the stock offset of the 2010. I'm taking mine into a shop and they are gonna pull mine off and measure everything then mock up some option to make sure I don't have any rubbing issues. I'll report back when I get some solid numbers.
