JWaldz
Moderator
Elocker... Check..
Got everything done and ready for testing tonight. I actually wound up using low ranges wiring diagram for the switch they sell. Here it is incase anyone was wondering.
Did you retrofit the wiring or use the ecu?
Elocker... Check..
I did a retrofit, it was really easy actually. Esp with the auxiliary fuse panel 2feet away from the switch.Did you retrofit the wiring or use the ecu?
Let me know if you want me to draw this stuff up in cad...
That would be killer. Unless it a pain to use. I tried Google sketch and that crap was hard, but I'm sure its nothing like cad. Let me refine it a bit and then we can see if we need it later. I will probably start it this weekend since we will have good weather. Atleast the bumper portion.
That or his SC is causing too much blood to rush to his head.
Got the first part of my bumper done tonight. Ill get some better pictures soon but here are some teasers.
The tire carrier should be pretty easy and only take a day or so. I ordered another rim to match the ones I have now and itll be here either friday or monday. I am still debating on wether or not I want to put some jerry cans on there or not yet. We will see how it looks.
What are your doubts?
