If you ever plan on removing your starter, read this first.
I've changed starters in a couple of late 80's pick ups (4cyl) and a 95 4runner (V6). Nothing to it, but you have to take your time to snake it out. It will only come out one way. If you snake the replacement starter in the wrong way, you can't turn it to mount it and will have to snake it out, and back in the correct way. If it won't snake out, you don't have it turned right to come out.
Dude, do you have pictures of what you are talking about? You make it seem so easy, but pics would help. I have a 2005 4runner sitting in my driveway and I can't even find where the damn starter is. I keep reading threads with these long explanations with no visuals. Seems to be on of no help to me. I need to see what it is you are talking about. Thanks!
This is for a 3rd gen 4runner (96-02). Your 4th gen is most likely different!
Would be probably best to search through the 4th gen section: LINK
Not really necessary to call someone a ****bird if they showed they way they did it, I took mine out through the wheel well, but to each their own madness right? If yours was easier then more power to ya!
I agree I took mine out the wheel well too and it really wasnt all that difficult you just needed to get the angle right. Glad you were able to get yours done :)
I've got no sway bar and it would not fit anywhere except out the wheel well... So... There is that...
I pulled the transmission dipstick (it pops/pulls right out), unbolted the hard brake lines from the frame (did not disconnect the lines!), and pulled it right out the wheel well (jacked up/wheel off obviously). Took all of 10 minutes.
It can never be as hard to remove as they are on the 3.0. Had to remove my buddies off his '92 pick up and it was a total b****.
So do all four runners have starters? I recently bought an "Eco-boost" hybrid 97 four runner, should I worry?
LOL JK,
Alright here's the real stuff, my runner takes like 4-5 cranks to get her going, should i do my starter contacts to rid this issue??
and I ****ing HATE when people write/type "four runner" OR "for runner" I mean come on! It's got a number in front!!!!!!
LOL JK,
Long crank is not a starter contacts issue. Bad contacts keep it from cranking at all. Yours is more likely fuel issue, filter, pump, regulator, etc. Gerdo is the expert, I think.
LOL JK,
Mine takes a several cranks too, but she always turns over :)
I am so sick of internet know-it-alls giving out ****ty information.
I swam through thread after thread after thread of all different tricks to remove your starter.
One guy says to unbolt the brake line and bend it out of the way, then remove the transmission dipstic
LoL. Pretty funny that despite your first post people went on to fill this thread with long detailed (and possibly wrong) "do it yourself" advice, exactly the kind that you are ranting about.
:rockthrow:
Disclaimer: My agression may be slightly elevated at this current time due to personal issues.
I am so sick of internet know-it-alls giving out shitty information.
One guy says to unbolt the brake line and bend it out of the way, then remove the transmission dipstick.
Listen to me
ALL YOU NEED TO DO IS REMOVE THE 2 NUTS AND 2 BOLTS THAT HOLD THE SWAY BAR TO THE FRAME AND THE STARTER WILL FALL RIGHT OUT.
I'll type it again
I just wasted 2 hours trying to snake this stupid thing out through the wheel well as this shitbird suggested.
It took me 5 minutes to unbolt the starter and contacts. 10 Minutes to work out the slightly rusty bolts on the sway bar. 12 seconds for the starter to drop out. Another 5 minutes to bolt the new starter and contacts. And 5 more to bolt the sway bar back in.
One more time...
I will concur this information. I will only add that you will need to remove a PS line and possibly the loosen or remove the upper half of the trans dip stick.
Much much much easier than any other procedure that I have tried.
Listen to me
I'll type it again
One more time...
thanks, I'll be giving this a try right now, it definitely seems much easier than snaking out the starter at various angles...
Well, I removed the bellhousing/tranny/tc and swaybar brackets, and then it was a breeze to take out going to the rear. (Of course, what I really had to do was my clutch. I only had a mm or two left on the contact so it was a good time to do it.)
If you are over 120k and have the trans out for any reason, I recommend doing this at the same time.
Let me knows if it works
That definitely worked! It was very easy to simply unbolt both front sway bar brackets and drop the starter out that way (but make a note of how it came out!).
I had initially planned to just swap the starter contacts without fully removing the starter itself (based on THIS THREAD), but once I unbolted the three (3) 7mm bolts and removed the cap, I realized my starter was full of debris, so I decided to just take it out completely and clean it on the bench, which was fortuitous because I would never have been able to remove the contacts from the starter under the 4Runner because they were just so tight...
By the time I cleaned the inside of the housing and replaced the worn plunger & both contacts and bolted on the cover, I tried to put the starter back in the way I had taken it out, i.e. past the front sway bar, but I just could not remember how I had oriented it for removal... so I ended up getting the started back in place via the passenger wheel well; I had already previously unbolted the two (2) 12mm bolts which keep the brake line in place on both the outside and inside of the frame (based on THIS THREAD), and it was very easy to maneuver the starter back in place that way.
Now my starter starts right up again, and so I hope my intermittent starter issues (clicking, and one time recently, the starter still attempted to start both when the engine was already running, as well as when I tried to shut off the engine and removed the key from the ignition! *) are a thing of the past...
* according to ExPo - Denso starter contact replacement, the starter contacts can get pitted and worn down to the point such that when the starter engages, the plunger can stick between the channels dug out of the contacts, keeping the starter engaged, even if you remove the key from the ignition - there is full battery amperage going through the motor, and so if this happens, then you run a great risk of your vehicle catching fire! BTW, this particular thread was a good reference for all the proper torque specs (stud nuts and cover bolts), as well as the piece of steel which Dave machined to apply force to both the starter contacts while properly torquing down the 14mm stud nuts on the outside of the housing.
Having done numerous starters on all types of Hondas, I thought this would be straight forward with two bolts, remove cable/wire and pull out. But NO! This was such a PITA. Took me roughly 45 min. to get the starter off of the block. It took me 3 hours to get it out of the damn engine bay! OMFG!
I tried through the wheel well but the brake lines were in the way even though the bracket was removed. Finally got it through the bottom by dropping the swaybar, removing the transmission dipstick holder bolt AND undoing a power steering hardline. Haven't put it back in but hopefully things will go much smoother. Wow and I thought these things were easy as Civics to work on.
I've done 2 2nd Gen starters, on my old '94 and my dad's '95. The only way those go out is through the wheel well. What. A. Pain. In. The. !#@$!
erinobr2000
