I'm lost
lionchops
So I know I'm gonna get in trouble for this and I apologize in advance. I have trouble with the search function here.
I have a 2016 limited and I'm doing the diff breather mod. Is there a breather valve for the center diff? And where is it?
I thank you for your patience and I plan on sacrificing a goat to honor you for having to deal with me!
Hey dude... go to google.com and type the below
site://www.toyota-4runner.org/5th-gen-t4rs/ breather mod
The key is site://www.toyota-4runner.org/5th-gen-t4rs/
This works for most websites or forums at least.
And don't feel like you will "get in trouble" ..
[MENTION=66316]1engineer[/MENTION] make note of the perception :tape2:
Sometimes just typing in something like 5th gen rear differential breather toyota4runner.org will help or different combinations in a search engine....
But, here is a link that may help you: http://www.toyota-4runner.org/5th-gen-t4rs/150158-rear-diff-breather-mod-complete.html#post1474622
The center diff on the Limited is inside the transfer case. I believe that the transfer case breather is already remote mounted up on the firewall about the elevation of the air intake. Look behind the engine. If you're in water that deep, a little water in your transfer case isn't what should worry you.
The rear diff is located in an area that is easily submerged, but instead of routing a hose to a breather in the engine bay Toyota went cheap and installed a one-way breather. But that can cause its own issues, which is why people do the mod.
As for searching here, don't search here. Go to Google and search for "[search terms] 5th gen 4runner". About 90% of the answers will send you here, with maybe a few to some of the other 4Runner sites.
Thank you!
I use the search within the forums and have trouble finding things. That clears things up a bit.
I did do the diff breather mod. I used the Arb kit and it was pretty easy. But it seemed that all the people doing them had trail 4Runners. [MENTION=75328]DannyLlama[/MENTION], [MENTION=103267]Saker[/MENTION]
[MENTION=126566]jwkilgore[/MENTION]
Thank you so much for the explanation.
This site has taught me a lot so far. But sometimes in can seem a little intimidating to ask a question. As I was under my truck looking for the center diff breather valve I thought perhaps maybe I was blind.
But now I have my answer and hope to share with others.
Thank you!
Wish I would have seen this sooner, would have sent you this...
http://www.toyota-4runner.org/5th-gen-t4rs/215741-rear-differential-breather-mod-dummies.html
It's amazing how good life is when you throw yourself on your own blade...the world is at your feet..
One of the most humble suicides I've seen here in awhile..great job.
I honor your memory...
The transfer case, transfer case engagement and transmission breathers are centered behind the engine between the firewall and engine and above the transmission torque converter cover.
I took a picture but it is hard to see the details. There are two dark breathers which are the transfer case and actuator breather then there is a white topped breather for the transmission to the right. all three are next to each other.
Hope the explanation helps to find it. I tried to center the items in the frame.
[MENTION=3442]Boyds4Runner[/MENTION]
Thank you for the picture. I don't think I am ever gonna be that deep in a puddle at the mall, but you never know. Thank you.
[MENTION=47340]Titanpat57[/MENTION] whilst being humorous appears to offend, I meant no offense by it. Rather I sought to use humor as a way to diffuse. And since I didn't know what I was doing or where to look on my truck, I saw no reason why not to poke some fun at myself. There is a lot of knowledge here. But it's also hard to access. I use my iPad and an app called tapatalk. It's not the best way to search. But neither is the search function on the website.
I used the threads I could find. But not many people seem to do this to the limited. I could be wrong.
Also this is gonna be my first truck I mod the hell out of and make mine completely. I'm also 40. I'm not a car guy and I've never done anything like this. So I'm learning. I'm sorry if I offended you, but not that much. If you don't like my questions, don't answer. No skin off my back and there shouldn't be any from yours. Life is too short.
[MENTION=120701]Cymon[/MENTION], I figured that was written specifically for me. I couldn't find the little u shaped tubing that held the breather for the center diff....of course it's further up and not u shaped. Point in fact, it's completely different.
I wanted to look into extending these to the ARB breather I have on top of the driver wheel-well. I have the rear-diff and e-locker going to the front and I extended the front-diff and actuator breather to the same.
Once I saw where these breathers were located I decided against trying to extend the transfer-case, actuator and transmission breather. I was flat on my back in the garage underneath with all skid plates removed. I could only fit one hand in there and had to fully extend my arm and push off my other shoulder to get to those breathers. Not to mention at that point I couldn't see so it would have to have been done by feel.
As long as you are moving forward it should keep water from stuffing the breathers where they are. Standing in water to the top of the tire may be a different story.
As much as we may love our 4Runners, they were not designed for 3' deep mud holes at the mall.:hatsoff:
I did it on my limited and ran it to the tail light.
The best way to find info here is simply Google it and put 5th gen 4Runner in the bar with your keywords. It will come right back here with what you need.
If you re read Pat's post you will see he said basically the same thing you did lol.
Have fun here and make sure you read the sticky about new or prospective owners. It has lots of links and answers. Enjoy the 4Runner!
The tip about using Google search instead of the forum's own search feature is a good one. It took me a while to figure that out on my own. The forum search just isn't as powerful or sophisticated as Google's.
The stickies have been mega helpful. And now I know about Google instead of the forum search.
I'm not out to be a jerk. But to learn and share knowledge as I can. This place has been a treasure trove of stuff.
Thank you to all
I did it on my 2010 Limited. Pics and details are in my build thread. Shouldn't be that different from your 2016.
Okki
goddesszilla
