Installing a Pioneer FH-X700BT into a 99 limited. Need help!
Clos3call
Hello everyone, this is my first post on the site and sadly it's a request for help. I got a new pioneer FH-X700BT stereo for christmas and can't seem to get power to it. My stock stereo works just fine but for some reason the new stereo just isn't getting power. The only difference in the hookup is that the small, what i believe to be a rear antenna, cable isn't hooked up. Any input?
are you using an aftermarket radio to stock wiring harness adapter?
those are pretty bullet proof... just match the colors.
and, yes, remove the factory amp.
joel
My advice ... run new power (+) and (-) 12G wire from the battery to the new head unit. You must also put a simple $5 fuse (any auto parts store) within 10" of the battery on the (+) wire.
This will help you avoid that "engine whine" that some people get with aftermarket head units.
I just installed a Sony head unit a couple of days ago, and I found that I did have to bypass the factory amp in order for the wiring harness to clip together. It should be two plugs, one smaller than the other that clip together. As long as you match (color to color) the wires, you should be getting power just fine. Good luck.
TerryNap61
