Installing TRD Pro bumper trim pieces on SR5
Can anyone please help and confirm the black front valance bumper part number is 53901-35250. I wanted to place an order from Toyota Online parts, but its pulling something up different (Panel Sub -Assy FR V). I just want to make sure I am ordering the correct part. I did go back through the threads just to make sure I did not miss anything.
Thanks in advance
Try the following;
TRD grille garnish - PZ323-35056
TRD upper grille - PZ327-35053
Edit: I misunderstood, I was thinking the grill piece, disregard.
Try the following;
Thanks. No worries. Yeah Im actually trying to look for the front bumper valance part number.
PZ323-35056 Toyota Garnish 375.04
PZ327-35053 Grille, Radiator, Upper 160.79
toyotaonlineparts.com
Thanks NuclearN8, I was looking for the front bumper valance. The part number (53901-35250) noted in this thread just didn't match what was on Toyota Online Parts.
Thanks in advance
Looks like nobody answered the question....YES, that is the correct part number for the Front Bumper Valance. I ordered mine from TRDShop.
Awesome. Thanks so much Diesel. I will be placing the order for this item now. I'll check out TRDShop.
Hello, I'm new to this forum.
I'm trying to install the bumper but I'm stuck at step 2 Removal-Vehicle Parts "pull the grill to remove it." The grill does NOT want to come out. I'm not the handiest person, and I don't want to crack anything. Has anyone else had this problem.
Drink more beer. Pull harder.
Seriously, it's a tough piece to get out. I got mine starting with the sides, and then using a combo of pulling the front and pushing the back in the middle to get it to pop. The plastic seems pretty tough though.
Thanks! I got it out. You just have to pull. It comes out with the painted part on top. I feel pretty dumb now. Turns out the instructions are pretty accurate! A little too accurate... 49 Newtons of pressure for the adhesive? Who knows what 49 Newtons of pressure amounts to, LOL.
New TRD Pro Grill
Hi, new guy here. Just installed the TRD grille on my trail. Was wondering if the TOTOTA piece fit perfectly for everyone or if they had small gaps on the side?
sr5 to trd bumper conversion
trying to do a conversion from a sr5 front to trd pro front after i got into an accident a couple days ago and bumper needs to be replaced. read the prior post and have come to the conclusion that i will need a new bumper plus...
1. GARNISH FR BUMPER - TOYOTA (PZ323-35056)
2. GRILLE RADIATOR UPR - TOYOTA (PZ327-35053)
3. BODY/BUMPER & COMPONENTS - FRONT FOR 2015 TOYOTA 4RUNNER
Can someone please verify? The body shop I'm working with will help me out with installation as long as part/part numbers can be identified.
If these are correct, is the fitment pretty flush?
Mines had that gap spacing also. Very minimal.
It is the easiest thing I have ever done to a vehicle. Took 20 minutes. Detailed instructions are included. No tools needed other than a screwdriver and trim removal tool(barely). Push the button on the clips and they pop loose.
nice! I'm planning on switching out the upper grill
All great stuff here and the rides look good! I went with having my front matted by a local body shop. I thought about doing the TRD Pro look but decided against it as everyone near me is doing it. I work at a Toyota dealer so see it everyday.
I've been looking for threads where people have matted body and trim pieces. I'm specifically wanting to get my OEM fender flares matted black to match the black TRDP bumper trim pieces. I don't want to use Bushwackers or any other aftermarket fender fares; I just want to get my OEM ones modified to match the black on the TRDP factory bumper trim.
I feel like I know enough to comment at least somewhat intelligently in the occasional mechanical or suspension thread, but I know NOTHING about paint or body work.
Any advice? Is this something that any body shop should be able to do? I'm assuming that a matte black paint job would be a closer match and more durable than vinyl wrapping, but I may be totally off base on that, too...
Remove Inner Plastic
Swapped the rear hatch handle panel out for the TRD/TE panel (black), and then applied the blackout kit.
Shout out to [MENTION=28870]d_clark[/MENTION]
Next up, rear bumper garnish...
I have looked at the info provided by [MENTION=28870]d_clark[/MENTION] but I still am not sure how to remove the plastic on the inside of the lift gate. [MENTION=22701]hookem[/MENTION]' Horns! how did you do that and did you need any new clips to re-install it? I have to do mine thanks to a little accident the wife had with the garage door.
Is this bracket necessary for the grill swap trdparts4u is saying it is.
BRACKET RADIATOR GRI - TOYOTA (PZ327-35701)
This is to put on a Trail Premium
I would like to know as well as I am looking to do the same...
delislerebecca
