JFry's Build Thread
What LEDS are these in the controls? Look like they have the fewest hot spots of any I've seen. Looks awesome!
I soldered all of the various button leds and HVAC leds with resistors...I didn't use plug and play leds.
Threads on led conversion:
http://www.toyota-4runner.org/4th-g...ter-hvac-switches-window-*steering-wheel.html
http://www.toyota-4runner.org/4th-gen-t4rs/204633-yosh2000s-ultimate-led-swap-info-thread.html
----------I used:
----PLCC-2 (for cluster and steering wheel controls): https://www.oznium.com/plcc-2
----3mm flat top (for HVAC, HVAC display, DAC button, side curtain airbag button, center diff lock button, 4wd switch, rear window switch, driver window button, air bag on&off) : 100x White 3mm Flat Top LEDs Wide Angle Light Lamp LED USA | eBay
(if you're replacing a filament light bulb then you need to add a resistor, if you are replacing an LED then you don't)(HVAC display{2 bulbs} run off of ~7volts...so you need a resistor)
----560 ohm resistors: https://www.amazon.com/gp/product/B00CHTOB02/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
----#74 LED (for glovebox, console gear selector, cup holder): https://www.superbrightleds.com/mor...b-3-smd-led-miniature-wedge-retrofit-car/228/
EDIT: SOLDERING TWO BULBS TOGETHER LIKE BELOW DIDN'T LAST. SWITCHED TO ONE BULB AND A RESISTOR, THIS SETUP HAS BEEN RUNNING STRONG FOR 6+ MONTHS.
Here in post #43 of this thread
Went to Uwharrie National Forest for some trail riding. Beautiful weather this weekend.
Great build thread!
Wondering what your estimated net lift front and rear might be? I just installed about a 3.25/2.5 lift and am wondering what I can get away with for tires. I would like to go with 285/65/18 (the equivalent to yours) but I’m worried about too much rubbing. Did you encounter any when you installed?
Thanks!
Hit a deer a few days ago. I think my Demello Offroad bumper paid for itself since I had no damage from the impact. A stock bumper would if exploded.
Great bumper [MENTION=59079]jdemello[/MENTION]
Just had a little blood and hair on my synthetic line Splicer.
Really woke me up driving home from nightshift.
erinobr2000
