Joining the 6112/5160 club this weekend!
Snugg
My XREAS is failing so I decided to go with an upgrade!
A little teaser pic for ya.
Ended up going pretty smooth install wise. I love the way it looks now and especially how it handles.
Removed the XREAS system of course. Old system was leaking.
First pic is stock
Second pick is with a spacer lift. "3/2" Cornfed/Daystar
Remaining pics are end result of 6112s/5160s
Stock
Cornfed/Daystar spacer lift
Bilstein 6112 @ 4th notch with BurtmanIndustries small spacer in Front
Bilstein 5160/Wheelers springs rear
I haven't tested the down travel and the CV angles are decent. According to 4Wheel parts (did the alignment) the angles are great.
Good to hear. I am considering whether to swap out my springs for something that can provide more lift or do spacers. A bit torn. Bilstein said that they discourage spacers, as many others do.
Perhaps it depends on what your goal is for the vehicle you're lifting. Personally, I won't be using mine to it's full potential so the use of a spacer in addition to Bilsteins works well for me. I did consider no spacer, but after seeing so many builds here using them, I thought I would give it a try.
PS, just for verification, are you able to see the pictures I posted? I received a PM saying they can't be viewed, but I see them on my end.
No, I cannot view them. Did you use photobucket?
So what are your hub to fender measurements?
** Not sure if you changed something, but they are showing up now! Looks sweet man! **
I did use Photobucket yes, but I just changed it and used this sites photos. Hopefully they can be viewed now.
Front hub to fender = 24.5"
Rear hub to fender = 25.5"
That's crazy that yours sits so much taller. I have my 6112's on the top setting and I'm only at FR: 21.75", FL: 21", RR: 23.5", RL: 23.5". I need to figure out how to get mine to sit higher!
