Joshua Tree 3/17-3/19
Think he mentioned a diff drop on the other page.
All my parts arrived so it's time for me to get to work...tie rod ends, very through tune up, blue sea fuse block, install China led bar, install 12v outlet/dual USB ports.
Keep getting hung up on how I'm gonna wire this fuse block safely and tap into the ignition circuit so the block is turned off with the key.
cool, those are the channels i will tuned into unless drunner has a specific channel for us
I don't have a specific CB channel because mine's disconnected. Most of us have switched to HAM. Base camp will be 146.460. Individual runs will be decided by the lead, but I'd prefer to keep off 146.460 away from camp as that's what I'll be monitoring for people coming/going, maybe lost, etc.
Run dual batteries, then you don't have to worry about the ignition switch. hahah.
You could probably put an isolator in between the starting battery and the fuse block. Then run the energizer post to an ignition switch via an add a fuse.
I'll likely be running ham as well. Good to know the frequency
I'm good at electronics. Pm me if you need help
Hey D2 :) How many kids are coming? Just want to make sure I'm bringing my 4 year old to a situation where it might be a bit out of control for his age .. Thanks buddy
I will have my kids and where I camp will be kid friendly if you decide the main camp is too wild.
I will sadly have to cancel this trip as I just got T-boned this morning on my way to work.
Everyone is alright except that I fear that the truck might be totaled.
I will be swapping out these tires before the adjuster shows up so please let me know if anyone has a set just laying around or looking to get rid of an old set for a cheap price.
Will be sad to let her go but its time to look for a new black 4th Gen 4x4.
Shit Mikey! Glad everyone is okay. That's a lot of damage on an old vehicle, especially if the frame is tweaked.
[MENTION=132593]Mikeson[/MENTION] Glad you guys are ok but gives you a reason to upgrade to a 4th gen v8 4wd brotha!
BillM777
